Hi,
Having never had a garden before and never owning even a flymo in the past I now find myself with 4 acres and a Kubota L3200.
Enormously grateful if anyone would be patient enough to explain what are going to be obvious and stupid questions.
1. It looks like the hydraulic oil level is a bit low and it only just edges onto the sight glass. Problem is that where I expected to find the filler there is something attached by hydraulic hose to this. (See photo).
What does this do and with it seemingly permanently plumbed in how do I top up the hydraulic fluid?
2. When I use the grass cutter should I lift the deck as I turn or not bother?
3. It seems to cut okay at slightly lower revs than where the PTO is marked as being 540rpm should I always run it at the PTO marker even if it is cutting okay.
4. It was last serviced Feb 2021 but has only done 18 hours since then. Is it worth the bother of servicing now?
5. The grass cutter is a bit rusty underneath, is it worth perhaps power washing it and using some rust treatment on it?
6. Where are the best places to order fluids and filters from etc.
Sorry to barge in as a new forumite and be so immediately needy.
