So it was 71* last Saturday and with the rain/snow melting my yard was pretty soft. I figured it was good conditions to roll it. I still had the turf tires on the BX2200, but thought to myself "It'll be fine".....
Well, obviously it wasn't. I was rolling along fine and then hit an extra soft spot and sunk. Tried to get out, but all it did was make trenches and eventually dig deeper and deeper. I could pull myself along with the FEL, but couldn't get the tires out of the ruts.
So then I decided I would pull it out with my Excursion. Pulled around back on semi firm ground with no issue, but my chain wasnt long enough. rolled forward 10 feet and the Excursion sank too.......clear up to the axle.
Ended up having a tow truck winch out the Excursion. I I was able to use a come along to get the BX up on 2x12's, but it would get stuck the second it rolled off them.
Left it there for a few days to let it dry out a little. Then I swapped out the turf tires for my AG ones. Was able to drive right out. Still left some shallow ruts, but didnt lose traction or spin the tires.
So the lesson is.......If you are feeling lazy and think "It'll be fine", it probably won't. Enjoy the pics. Hope ya'll get a good chuckle at it.
Both Stuck
Ruts from the tractor.
Ruts from winching out the Excursion
Tractor up on boards
Finally Free
Both Stuck
Finally Free
