Good for a laugh
bird dogger
Vendor Member
Feb 24, 2019
1,644
1,535
North Dakota
Jeremy, I can't find the beer hidden in that first picture??? Welcome to the "Club". You're not alone!!
William1
BX25D
Jul 28, 2015
1,138
334
Richmond, Virginia
Its supposed to get back down to 29* this coming weekend.
I was thinking about getting a winch that I could use in the future.
That is what I use. A winch installed on a receiver mount. Ran 0/0 cable to Anderson Plugs next to the receivers. Two minutes to install on what needs it.
I can install the winch on the tractor or my pickup. Good for pulling trees when cutting to make sure they go close to where I want and it gets me unstuck (4 times and counting!). I have a Warn with a wireless remote, good for (a safe) 90' distance.
4,389
If you drive off-road long enough getting stuck is more a matter of when than if. Which is why everyone really needs at least two good tractors.
jyoutz
Jan 14, 2019
3,211
2,250
Edgewood, New Mexico
So it was 71* last Saturday and with the rain/snow melting my yard was pretty soft. I figured it was good conditions to roll it. I still had the turf tires on the BX2200, but thought to myself "It'll be fine".....
Well, obviously it wasn't. I was rolling along fine and then hit an extra soft spot and sunk. Tried to get out, but all it did was make trenches and eventually dig deeper and deeper. I could pull myself along with the FEL, but couldn't get the tires out of the ruts.
So then I decided I would pull it out with my Excursion. Pulled around back on semi firm ground with no issue, but my chain wasnt long enough. rolled forward 10 feet and the Excursion sank too.......clear up to the axle.
Ended up having a tow truck winch out the Excursion. I I was able to use a come along to get the BX up on 2x12's, but it would get stuck the second it rolled off them.
Left it there for a few days to let it dry out a little. Then I swapped out the turf tires for my AG ones. Was able to drive right out. Still left some shallow ruts, but didnt lose traction or spin the tires.
So the lesson is.......If you are feeling lazy and think "It'll be fine", it probably won't. Enjoy the pics. Hope ya'll get a good chuckle at it.
Both Stuck
Ruts from the tractor.
Ruts from winching out the Excursion
Tractor up on boards
Finally Free
Now you have some more lawn areas to roll.
JeremyBX2200
BX2200
Aug 3, 2020
467
439
Indiana
That is the setup I was looking at. I liked the idea of the hitch receiver allowing it to be moved from vehicle to vehicle easily when needed
William1
BX25D
Jul 28, 2015
1,138
334
Richmond, Virginia
This is my setup.
JeremyBX2200
BX2200
Aug 3, 2020
467
439
Indiana
This is my setup.
That is the same kind of setup I was thinking. For using it, did you upgrade the battery or charging system on your BX?
RalphVa
738
320
Charlottesville
Both Stuck
Finally Free
Hope you're enjoying feeding the rescue battleship.
William1
BX25D
Jul 28, 2015
1,138
334
Richmond, Virginia
Nope, no changes. I do keep the tractor running at a 'fast' idle. Make sure the fan belt is in good shape and properly tightened. I'd upgrade the alternator possibly but, I doubt I could fit anything larger under the hood. No room for a larger battery unless I went to a second externally mounted one but to date, I've have no need.
Keep in mind, the winch I have is twice as strong as the weight of the tractor. So the winch is easily capable of dragging the tractor with the wheels not rotating. It is not like we are extreme 4X4 where they lift a Jeep up a canyon wall.
The thing about most 'winching operations' is actual loaded winch run time is very short and often, intermittent, which gives the charging system a chance to recover the battery.
Once, I had to pull a tree out of my pond, mired in muck! I used a few pulleys to multiply the power (the tractor was getting dragged!) Getting the tree out took a couple of hours. The winch motor got hot enough to burn my hand!
Mot winching operations I do are when felling trees by myself. I'll get a rope on the tree, winch it the direction I want the tree to go, start my cut, stop, apply some more tension, cut and apply more tenson and the tree falls. I usually use a pulley on another tree so the tractor is not in the line of the fall and in a safe spot.
When I've used the winch to get unstuck, I'll use the remote control, sitting on the seat of the tractor and while the winch is pulling, I'll try to match it with the HST so the wheels are trying to help, working together. I'll watch the winch cable and when it goes slack, I'll know I am finally 'unstuck'. Until I get stuck again...
JeremyBX2200
BX2200
Aug 3, 2020
467
439
Indiana
Thanks for the info. I was just thinking about what size winch I would want to get. A smaller one would be fine for my BX, but I am also thinking about how I would use it on my vehicle (Excursion).
William1
BX25D
Jul 28, 2015
1,138
334
Richmond, Virginia
I selected the Warn because of the wireless remote. Certainly more winch than I need but it was the smallest Warn (4700#) offered at the time with wireless capability.
Smaller is also lighter (probably less current draw across the board too) and carriyng it to slide into the receiver requires a little forethought. No idea what winches are being offered today.
5,950
Jeremy, don't beat yourself up too bad! Every experience has value if you or anyone else can learn from it. That is where "common sense" is developed. Nothing broke, no one injured, something learned.....that's what life is. :)
JeremyBX2200
BX2200
Aug 3, 2020
467
439
Indiana
Thanks.
Yeah, I'm not too upset about it. If I got mad or beat myself up for every stupid thing I did I would be pissed all the time......:)
I learned some stuff and got to work outside all day.......and I figured some others might get a chuckle out of it.
Plus now I can honestly tell the wife "See, I really do NEED to buy a winch setup".
5,132
If you are going to own a winch, you should also have a snatch block to double or even triple the pulling power of the winch. Also, a long chain wrapped around a tree to hold the tractor helps a lot.
3,327
A winch may…..or may not…. be helpful…
I bought a 12K winch to pull my compactor-roller out …and never used it. My tractor couldn’t pull it out, so I thought I’d make a receiver-hitch winch-installation that I could move between the truck, the tractor, the roller…whatever.
I bought all the “stuff” and never used it. Sold it all to my neighbor at a discount while it was still new-in-the-box.
I learned instead to quit trying to roll turf within 3 days of the last rain. Problem solved. (after 3 times being stuck for days on end.… chalk it up to being a slow-learner on that thing)
JeremyBX2200
BX2200
Aug 3, 2020
467
439
Indiana
That looks like it weighs quite a bit
3,327
14,000 lbs empty…. 18,000 if the wheels are filled with water. I use it to roll my grass aircraft runway. That keeps the wild hogs off it because they won’t root-around on compacted turf.
I used to have a little 9N Ford tractor, and I bought the M4700DT Kubota to pull a disc-plow, tiller, and land-plane to repair the damage they’d done (which was so bad the little Ford tractor couldn’t even negotiate the ruts they’d made…. They really were THAT DEEP.
Turns out… the plow/tiller/grader-landplane couldn’t even TOUCH the damage. So I bought the Ferguson 5-8B compactor (ex hwy-dept machine)….and waited a few days after a rain…and VOILA! The runway was perfectly useful again. I then learned that when compacted the hogs won’t touch it…. So I roll/compact it a once per season and have never had a hog problem on it since. (They’ll tear up the areas/pastures (and the neighboring ranch :ROFLMAO:) outside the rolled-area….but they don’t even try the area I’ve rolled with this thing.)
Not really amused about the neighbors… just glad the damn hogs leave my place alone now.)
