Hey guys, I have a BX2370 that I bought used with about 300 hrs on it. It makes a fairly loud noise at the rear of the tractor. Sometimes I notice it more than others. Today it seemed very noticable. It is pretty loud at the operator seat, but definitely seems to be coming from the rear.
I was going to post a video that I took that captured the sound pretty well but I don't know how to post a video on here.
It kind of sounds like the whistle a turbo would make or a bad bearing even. It goes up and down with engine rpm and doesn't seem to change based on movement or hydraulic use.
I've read on hear about some BXs having a pretty noisy hydro. It sounds different than the normal hydro whine you get when you are moving or under load.
I'm just trying to figure out if this is the normal BX hydro noise or if I've got a problem.
I checked the hydro fluid and it's a good bit over the full mark and it looks the have the original hydro filter on it so I know the filter at the very least should be changed.
Thanks,
John
Thanks,
John
