Thank you to all who have responded so far!
Everything on the tractor works fine, all hydraulics seem to have plenty of power.
The only "issue" I have with the tractor is this noise. And if the consensus comes back that it is nothing to worry about, I'm good with that. That would be great in fact. I just don't want to keep using it if it is a sign of a problem coming on that could turn into a bigger problem, if that makes sense.
Posting a video is actually easier than I thought it would be if you have google account. You just upload to youtube and copy and paste the link here. You can even keep the video private, so it can only be viewed from the link. I'm sure someone can explain it better than I did, but it was pretty easy.
I found this post from 2011, his noise seemed similar to mine at about the 6 minute mark in the video.
Roll Bar Noise
Let's take a moment to talk about roll bar whine and engine noise. I have a BX1860 that has a ton of noise being resonated through the roll bar. Has anyone drilled and filled the roll bar with spray foam? I have tried foam spacers and isolaters with no luck. I called the dealer today and...
www.orangetractortalks.com
