I believe those are port reliefs which are typically screw in cartridges. Not enough room to put them in the body.Maybe I should start a new thread, but I have the drooping problem as well and the previous information is pertinent to my question. I have the BH70 backhoe, the parts diagram shows the relief valves like the BH77, but with slightly different part numbers, I see no relief valves like that on mine. Maybe there was a change and the parts list is not up to date. I would think that there must be pressure relief, so does anyone know if relief valves are now embedded inside the valve block?
