The boom cylinder is drooping on my BH77 which is on a 2008 L3400 HST with 600 hours. There is no fluid leaking anywhere. I put a blue Viagra pill in the hydraulic reserve, but it still droops overnight. Haha... anyways, when digging and the tractor is warmed up it suddenly won't lift the arm and bucket up. I have to wait a couple of seconds and then pull back on both levers to get it up. The dipper and bucket cylinders appear to work fine. When parked the boom droops unless the safety latch is set.
I Took the rig to the Kubota dealer and they recommend replacing the Control Value and Pressure Check Value for $2360!? What the...$$! They're charging me $400 just for doing diagnostics on the boom cylinder line to determine that the pressure was indeed fluctuating. I'm bringing the rig home and plan to take the control value and pressure relief value apart, clean it, reassemble and hope that in the process I find a bad o-ring or some obvious reason for the leakage.
Anyone have advice about this drooping issue beyond buying the backhoe flowers and dinner or has anyone done a control value rebuild? I've seen the job referred to in threads but no details.
