I didn’t even think about the fuel filters…..
The filter in the diagram that Wolfman pointed out - (180) is a royal PITA to get to and change!
I would remove as MUCH fuel from the tank as possible, not dry, just lower it.
Get a good set of fuel hose wrench clamps or use locking pliers with soft insert and pinch the hose prior to the filter.
I would personally get a 5/16 (8mm) 1/4 ball valve and place that on the end of the hose ONCE you remove the filter and then get another small piece of hose and continue the run.
Several of us have relocated the fuel filter to the front - which is a little more involved.
ONCE you get the new filter installed and hoses clamped again - fill tank, and turn key and hold for a full 30 seconds to a minute! The fuel pump will tick-tick and so on............. then it will change sounds, the tick tick will change pitch....... keep holding the key.
then start engine - it may sputter or run a bit poorly for a few seconds - if it does not clear up after a few seconds, re-bleed the system.
Report back after the filter change
