In cleaning out my closets in the basement of the carriage house, I cam across 2 gallons of unopened JD Hy Gard lo vis HST oil. Tried advertising it for $10/gallon on a local network and also on Craigslist. No bites. I'm inclined to get a couple gallons of UDT2 and take a little bit of both mixed together and warm them up to make sure there is no precipitate. Then use 50/50 for the 400 hour change. The UDT2 is between Hy Gard lo vis and high vis stuff in terms of viscosity.
Also had a gallon of JD CoolGard. Will use it at the first coolant change. No mixing there. Just drain and refill.
Anyone use some leftover Hy Gard? Think mine was from 2013 when I bought the 1025R lemon that I only had for a couple years.
