I got two seldom used, fan assisted wall mount 5000W heaters from my brother. He used them occasionally for about two years and then had a heat pump added to his detached garage. They were new when he installed them. I want to put them in my two car garage but have never wired a 220V switch. I'm fine with the breaker, running the wires and wiring the plugs. The heaters have 4 prong cords on them. The thermostats are internal and controlled by a knob on the rear. I need to know if i need two 30A breakers and two separate 10/3 feeds or can I feed them both from one switch. Also need some info on the switch(es).
