So I am back to working on the 1990 L2850. I had a no fuel on cranking the other day, so I checked the fuel filter and found what you see in the pictures. I did not clean out the fuel tank after I bought it, so I am dealing with whatever is in there from the previous owner. Strange thing is, is that it was 30-34 degrees finally when I had this problem, I would have thought it would have happened at colder temps. Now the crystals stayed solid until I brought the whole mess into the living room( please do not judge me for the pizza box, it worked), as the crystals warmed up to 70 degrees they just turned clear and melted away.
I am wondering if this stuff may have been part of a "water-a-way" sock that fell apart and spilled in the tank.
I have replaced the filter and flushed some fuel through the lines, but I have what appears to be a no fuel related no start again.
