QH15 pins
Lonesouth
26
23
Tallahasee
I just picked up a QH15 for $250, but the seller did not include the pins. I found the part number, 310-020S and messicks has them for $20 each, but I figured I would check if there is a cheaper alternative available. Since these aren't bolted to the adapter, I figure more than one person has had a pin walk off.
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,356
1,781
Western MT
Are you talking about the pins that holds the top hook on? A few of us have replaced those with bolts. They are 1/2 inch. I used 2 3/4 inch ones and grade 8. You probably could get by with shorter ones. If you have QH compatible implements, you won't need to adjust the height once set. I paid $10 for nuts, bolts, lock washers at the local hardware store. That was for two sets.
Bmyers
May 27, 2019
3,293
3,849
Southern Illinois
According to the part number you are talking about part number 7 on the picture below
i7win7
Feb 21, 2020
3,379
3,982
Central, IL
Think a 7/8" bolt works or just use 2 cat1 implement pins, only a couple bucks each
leveraddict
Apr 1, 2019
907
589
NEPA
Go to Tractor Supply Store!
RalphVa
738
320
Charlottesville
You can get pin #6 MUCH cheaper at TSC. My HF QH had those push-on type pins (vs. the #6 that snaps back). Lost one of those, and the large pin almost came out. Replaced with a lookalike to #6 (from TSC).
I'd recommend getting some silver tape and taping over the #6s after they're snapped flat. That what I just did in moving the QH from the JD to the B. Had them taped after that pin came out on the JD.
Lonesouth
26
23
Tallahasee
I was able to use these in the lift arms
after mounting the QH15, I discovered that my bargain basement trailer hitch attachment was woefully too short to work, so I ordered a titan
Then I blacked out and woke up in the silly land of quick attach bushings. So I ordered two sets of these
PSA: make sure that second hand quick hitch has all the pins and bushings or it may not be quite the deal you think it is.
