You can find the part number for the BH77 hose kit on the Kubota parts website.Does anyone happen to know what the part number is for the rear hydraulic hookup kit is for an L2501? Needing a single feed kit for a BH77 backhoe
Thanks!
Yeah I checked the part breakdowns for both the tractor itself and the BH77 Backhoe....It appears to be a secondary/ aftermarket kinda deal???You can find the part number for the BH77 hose kit on the Kubota parts website.
Assuming you already have the LA525 loader its not really an afterthought. The hydraulic takeoff for the L01s is an aluminum adapter block that bolts to the underside of the tractor. It gives you three ports:Yeah I checked the part breakdowns for both the tractor itself and the BH77 Backhoe....It appears to be a secondary/ aftermarket kinda deal???
I found this on Messicks: Kubota: KIT POWER BEYOND, Part # 77700-06110 (messicks.com)
But unsure if it'll fit my L2501 or maybe it's universal and fits all Kubota tractors??? The page doesn't say...
Thoughts??
and Thanks!!!
yep LA525 loader is installed….so I think I’ve watched a video on what you are referring to….there’s a power beyond return port on the distribution block right in front of the loader control handle and then another block under the right step and you install the hoses as you described…….but I am specifically looking for the OEM kit…trying to keep things matching and kubota approved!Assuming you already have the LA525 loader its not really an afterthought. The hydraulic takeoff for the L01s is an aluminum adapter block that bolts to the underside of the tractor. It gives you three ports:
One is pump out to an implement
Two is pressure return from the implement to the 3pt
Three is a tank return
The valve on the BH77 does not have a power beyond port and cannot withstand back pressure on the tank port so it is plumbed as follows
If you have a loader you use the power beyond port on the loader valve to supply the backhoe.
If you DO NOT have a loader you use the pump out port to supply the loader.
In both cases the tank port on the back hoe goes to rhe pressure return port and the 3pt must be kept in the full down position when the backhoe is mounted.
When the backhoe is dismounted you loop the pressure supply back to the pressure return.
You can do that with $75 worth of hose and couplings but ut wont have the nice brackets that come with the Kubota hose kit.
The hoses, brackets, and couplers come in the subframe kit (there is a few subframe kits for BH77). I don’t think they break down the numbers in the manual but I’ll check later.yep LA525 loader is installed….so I think I’ve watched a video on what you are referring to….there’s a power beyond return port on the distribution block right in front of the loader control handle and then another block under the right step and you install the hoses as you described…….but I am specifically looking for the OEM kit…trying to keep things matching and kubota approved!
Thanks for the info!
If you want to roll your own just loader valve power beyond to backhoe IN and backhoe tank to hydraulic block. The Kubota kit is just a bulkhead mounting bracket for the return line which gives you a neat way to loop the power beyond feed to the backhoe back to the tractor when you remove the BH77.The hoses, brackets, and couplers come in the subframe kit (there is a few subframe kits for BH77). I don’t think they break down the numbers in the manual but I’ll check later.
I agree, there isn’t anything to it. My L is basically identical to the 2501, takes the same subframe kit. I added the BH77 later on and did the install. Was just trying to help OP get what he was looking forIf you want to roll your own just loader valve power beyond to backhoe IN and backhoe tank to hydraulic block. The Kubota kit is just a bulkhead mounting bracket for the return line which gives you a neat way to loop the power beyond feed to the backhoe back to the tractor when you remove the BH77.
This might help (hope the link works right) parts list for the 4988 subframe kit for the 2501. Will get you part numbers, unsure of availability on them.yep LA525 loader is installed….so I think I’ve watched a video on what you are referring to….there’s a power beyond return port on the distribution block right in front of the loader control handle and then another block under the right step and you install the hoses as you described…….but I am specifically looking for the OEM kit…trying to keep things matching and kubota approved!
Had another thought on this…Does anyone happen to know what the part number is for the rear hydraulic hookup kit is for an L2501? Needing a single feed kit for a BH77 backhoe
Thanks!
