Looks great. Could not ask for better considering that most chains need adjusted to fit the tires they are used on...View attachment 72572 View attachment 72582
You can see where I tied the ends together in these two views.
Thanks Henro. I had to remove about 2/3 of a hexagon to make them work but it went pretty smooth. I have some spare parts now : )Looks great. Could not ask for better considering that most chains need adjusted to fit the tires they are used on...
Thanks for taking the time to satisfy my curiosity! And maybe others' as well.
Pressure is always a compromise, the surface you are running on, possible sharp objects, ride, ease of steering and tire wear are some of the considerations. As long as you stay below 60 psi or the wheel rating, you are safe. Usually the recommendation in the manual is a good starting point.Quick question on tire pressure. I helped a buddy load a log, maybe 28" diameter today. I noticed front "drivers side" tire was low. I had a compressor and no gauge so I just added air till it looked "full." I put the tractor in the shop after and checked front tire pressure. It was 26.5 psi on the one I added air to. The other tire pressure was 27.5 psi. I have never added air to my tires (or even checked them) so I was surprised when I checked the manual and it recommends 20 psi for the front tires (10 - 16.5) even though the sidewall of the tire says 60 pounds max psi. Is running 26 or 27 too much pressure then?
What type of tires you running?I did a couple of searches on here about chains. I have a hilly mile of dirt and gravel drive to keep open here in Northern Michigan. We had a heavy and dense 12" drop last Saturday. I pulled the trigger on a 7' blade for the front that is scheduled to arrive mid-January. I have a snow pusher on the front now and a 7' blower on the rear of my L4630 GST. I couldn't make it up one of my hills Saturday and got stuck a couple of times. I want to order some rear chains and could use some advice about getting a set of duo H grip chains or the more aggressive (and expensive) doo H grip with V bar? I have not used chains before. Will the "standard" chains do or does it sound like I need more aggressive V bar chains. Thanks for any feedback.
https://www.tractortirechains.com/Tractor-Tire-Chain-DUO-p/duo263.htm
Duo Grip H-Pattern V-Bar Tractor Tire Chains | Tire Chains 'R' Us
Shop Duo Grip H-Pattern V-Bar Tractor Tire Chains. Free shipping on orders over $75. Image is for reference only, tire/wheel/rubber tensioners not included. Chains only. Chains are sold in pairs (2 chains) and will cover two tires..www.tirechainsrus.com
I hope you can tell from the pics I posted above because honestly (What type of tires you running?
That is one of my prized possessions, a Super Split wood splitter. I’ve had both their electric and gas model (that’s the gas model in the pic).Looks like R14s in the rears. What is that strange contraption in front of the door in the picture?
