Cyl only have high pres, hose on the bottom / have a blade on hitch used it 2 or 3 weeks ago / have 6ft pipe extended on blade "O" movement / hyd loader works fine / have had heater on tarp over 1 hr "O" MovementYou have anything ON the 3 point? Or is it in the air by itself?
Does that tractor have the down pressure adjusting valve?
Stand on the arms and hit the lever - (might be a challenge to do) and see if it will go down.
You have "new" fluid in the hydraulics? Last filter change?
Does the FEL work? - maybe you do not have one installed.
Shut off valve right down in front of seat ""DA"" ME /Thanks for the response / Nice site / used yesterdays tractor form many times & still will have to TO 20Cyl only have high pres, hose on the bottom / have a blade on hitch used it 2 or 3 weeks ago / have 6ft pipe extended on blade "O" movement / hyd loader works fine / have had heater on tarp over 1 hr "O" Movement
spin that knob once in a while to help preventing it from seizing up. Every time I run my grease gun on my little BX I adjust it open. Close it. Then Count back to where I have it set.Shut off valve right down in front of seat ""DA"" ME /Thanks for the response / Nice site / used yesterdays tractor form many times & still will have to TO 20
