Fuel gauge problems
Cobra427
L3560le. Bush hog, tiller, flail mower, hole digger.
Jan 13, 2022
Sylacauga, Alabama
I have an L3560 hstc so the fuel tank is under the cab. My problem is the fuel gauge stopped working. When I turn the switch on it goes to full and stays there. I am trying to find out if there is a ground problem or fuse blown but I don't have a wiring diagram so I don't know where the ground or fuse is. At the back of the tank I can see a 90 degree metal tube connected to the tank but I don't see a wire. If anyone here has an idea how to diagnose this problem I would appreciate the help. Thanks for any suggestions
s
5,257
1,047
I enlarged this WSM image to help you see where the sensor is located.
First check that a wire has not been pulled off.
Edit: adding more info
3,478
2,052
s
Since it goes to full, it is getting power. If the sensor is good, there's most likely a short between the gauge and sensor.
bambam31
L3800HST 4x4,R1,FEL, 6'disc, 5'bush hog,piranhaTB,6'grader,6'rake, 48"forks
Apr 3, 2014
321
27
23
Mobile, AL
The fuel gauge on my L3800 was stuck on full for 5 years. It just started working this past Fall.
Cobra427
Jan 13, 2022
Sylacauga, Alabama
Thanks for your reply. I am not much good with a multimeter, is there another way to check if it is a ground?
3,478
2,052
Pull the connector off at the sensor. If the gauge reads empty, the sensor's bad.
If the gauge still reads full, pull the connector off at the dash (may be hard to find without a diagram). If the gauge reads empty, there's a short in the wire. If it still reads full (not likely), there's a problem in the panel.
Looks like it's a yellow wire.
Cobra427
Jan 13, 2022
Sylacauga, Alabama
Thank you again, I will try that tomorrow...
dlsmith
BX2230, LA211
Nov 15, 2018
1,299
907
Goshen, IN
Yep, sometimes if you ignore a problem long enough, it goes away.
But not very often, usually it just gets worse.
massahosa
Kubota 2021 60
Jul 10, 2023
Chester NH
s
I am discovering that it is important to keep fuel tank full when storing tractor for long periods of time. It took 20 hours of use for my guage to start registering above 50% when tank was actually full. I believe oxidation is the cause
