ROPS too tall
Mossy dell
B2601 (2021) JD970 (1998) B2100 (1991) B6100E (1988)
Jul 20, 2020
274
125
sw VA
if it's a matter of hitting the raised door, and not the lintel above it, you might be able to adjust the door to give you enough clearance. I say this because I've got a standard height door on my garage and have accidentally discovered that my B2601 will squeak inside, barely contacting against the lip of the door.
Backing out is a different matter, as the ROPS tends to catch a bit on the door's lip, so it's got a slight pucker in it now. I need to adjust the door and no more lowering the ROPS—or forgetting.
My pre-buying research indicated I'd always have to fold the ROPS. I wonder if the R14 tires are lower than the R1s or whatever Kubota uses to list the tractor's height.
aaluck
Oct 9, 2019
946
771
Snowdoun, AL
You could just make a piece to replace the top part of the ROPS. Set the original aside and reattach it when you sell the tractor.
That's kind of what I was thinking. I'd do it and then if need be buy a new top part if that can be purchased separately .
DavyM
L3560HST SE, LP Box blade, Titan pallet forks, EA Wicked grapple (waiting)
Dec 7, 2021
BR La.
Same problem here. I labeled a box ‘ROPS’ and set it on the garage floor when I put them up. Seems like a good reminder.
Good idea but I would need a reminder to remind me to put the ROPS box out there...and a reminder of where the heck I put the ROPS box... :)
jyoutz
Jan 14, 2019
2,972
2,015
Edgewood, New Mexico
JimmyJazz
1,219
738
Pittsburgh, Pa
My B2601 smashed the garage door header as well the first time I used it. If I leave mine folded partially down it fits fine. I leave it that way. Cutting and welding it will lessen its effectiveness and devalue the tractor. I advise against it. Maybe the guy that you sell it to gets hurt on it 10 years from now due maybe or maybe not to your modification. It wouldn't be hard to envision some lawyer attempting to bankrupt you. Risk/reward. I like to ask myself "Whats the worst that can happen? "
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,410
1,691
Kalamazoo, MI
Possibly a bill of sale that states tractor being sold "as is"? As always, the horror stories abound with theoretical possibilities and little supporting evidence.
To the OP, raise your door header or build a more suitable storage building...either way it's going to cost you, might as well spend the money on your own terms.
BOOMROASTED
Kubota L3301
Apr 22, 2021
15
I’m cheap so I would either just make a reminder label and put it on my tractor dash, or have a sign made that hangs down from garage door when open that says “check your ROPS”
2,919
1,380
It can not be purchased separately.
  • Sad
4,897
I made my own top section,made from similar steel though I consider it a 'sun shade - light bar' unit. Highly unlikely I actually need ROPS,don't even have seatbelt on tractor anymore.
RalphVa
738
320
Charlottesville
I go under and around too many trees to leave the thing up, too. I'd probably hit a tree limb and cause it to rear up the front of the tractor or knock the limb off and have it land on my body or head.
On my first tractor, I bashed one of the light assemblies with a tree limb. $56. After that I moved the ROPS lights all inside the ROPS on that tractor and now the next two. No more bashed lights.
3,316
2,965
GeoHorn! You surpassed skeets!
How did you manage to post a post with no content? :unsure:(y) :love:
Edit: referring to Skeets's comment that he was not going to make a comment, but used words to tell us that...LOL
3,316
I wrote a post which I subsequently decided was not helpful…so I removed the text. Since these forums do not allow one to BEGIN a reply and then abandon it…. one must post SOMETHING… so a “period” was used.
ve9aa
Apr 11, 2021
1,202
982
NB, Canada
My ROPS are too tall to drive in the garage, so what I do, is always, always, always, back the tractor in.
That way, at least I am looking backwards and there is a CHANCE I'll notice the ROPS are up !
(if I drove it in, nose first, I'd have to remember they're up....at least this way, I am looking backwards)
This morning, before snowblowing, I added paper "signs" that hang off the inside of my garage door, that remind me to fold down the ROPS. With the garage door up, they hang down, nearly at eye level as my garage door is not as tall as most.
They aren't huge, so there's no guarantee, but at least there's always the CHANCE I'll see them.
4,897
re: abandoning a reply...
I just do crtl A,delete and the form clears all,returns to 'Write your reply...' in very light grey
2,965
I see! I gave you a dot more credit than your deserved! LOL
Thanks for the explanation...all in good fun...
5,545
A law suit over a ROPS would probably make a good comedy skit.
A few years back I was in a law suit over an eager volunteer getting injured while rolling a manure spreader off of a trailer. During deposition it became obvious the attorney was not familiar with a manure spreader. As I explained in detail what his client did and the circumstances he had to keep asking me questions so he could understand how it worked, why it was used, what the components of the implement did, etc. Quite amusing.
4,815
A few years back I was in a law suit over an eager volunteer getting injured while rolling a manure spreader off of a trailer. During deposition, it became obvious the attorney was not familiar with a manure spreader. As I explained in detail what his client did and the circumstances he had to keep asking me questions so he could understand how it worked, why it was used, what the components of the implement did, etc. Quite amusing.
