Grand series does.Tractors have speedometers ?
My guess is since the cruise control works on what speed you want set and your speedometer is not working, it can't set.Any thoughts on where to begin on a l5740 hydro cruise control that will not engage? Additionally the speedometer is not working but I don't think these 2 things are related?
Downhill, with a wind and on pavement, fastest I got was 18mph. Most time, I'm between 3mph and 6mph.Dang how fast does it go?
What does the speedo go up to?Downhill, with a wind and on pavement, fastest I got was 18mph. Most time, I'm between 3mph and 6mph.
It is digital, so I guess it could go up to as many digits could be displayed across the screen, maybe warp factor 5 or 6?What does the speedo go up to?
If you’re using it for ag purposes such as spraying herbicide/insecticide or applying fertilizer/lime, precise speed is a necessary component along with flow rate for proper application rate. Effective cruise control and accurate low speed speedo is needed for those type operations. I don’t do that type thing any more so I have no use for a speedometer and it’s a good thing since I don’t have one on my economy 01 series. Spraying operations requiring precise speed are left to my Mule which does have a speedometer.Tractors have speedometers ?
No odometer that I remember seeing, just the hour meter. Oil is changed based on hours on my machine. It does have a trip meter based on hours, an average amount of fuel used per hour, and the amount of fuel used total.Is there an odometer to go along with the speedometer? Do you change the oil based on hours or miles traveled? Inquiring minds need to know!
Clearly everyone is being facetious and that's putting it nicely. I'll just retreat deep into the WSM and pretend I know how to read wiring diagrams.No odometer that I remember seeing, just the hour meter. Oil is changed based on hours on my machine. It does have a trip meter based on hours, an average amount of fuel used per hour, and the amount of fuel used total.
Make sure the foot pedal is centered.Any thoughts on where to begin on a l5740 hydro cruise control that will not engage? Additionally the speedometer is not working but I don't think these 2 things are related?
To engage Cruise Control DeviceMake sure the foot pedal is centered.
Never seen a tractor with an odometer, but my Mule has both an hour meter and odometer. When you first get it you have to make a choice whether to time maintenance by odometer v hour meter. There’s maintenance schedule for both methods.Is there an odometer to go along with the speedometer? Do you change the oil based on hours or miles traveled? Inquiring minds need to know!
