Does anyone know where I might find the parameters for the fuel rail sensor. volts/psi
With key on it reads .3 volts, with engine running idle it reads .73. This is the test per the WSM. While cranking it has .7 volts. New injector pump and has fuel to low side 73 lbs. Will not start. Starts with gas rag and has same power it always had. Will not start without gas rag.
