Any single spool valve with power beyond will work. This is the one I haveHello 34by151, do you have details on exactly which valve you bought and how they are hooked up to the hoses for the backhoe? I would like to do the same thing as you have done here. Thanks!
Hydraulic Online - Shop Online | hydraulic fittings Gold Coast
Shop Online - Piston Pumps, Engines, Air Brake Fittings, Adapters, Swaging Machine, Sectional Valves, Stabiliser Legs, Cee Top, Diverter Valve
www.hydraulic.online
PB plug to suit
Just connect the T and C ports via a shorrt line to the back of the BX
The loop line goes to the P port
A and B goes to the top link ram
Same connection as the BH
