Daily Chuckle
i7win7
Feb 21, 2020
3,379
3,982
Central, IL
An old man was sitting on a bench in the mall when a young man with spiked hair came over and sat down beside him.
The boy's hair was bright yellow and green with orange tips, and he had blue makeup around his eyes. The old man kept looking at him. The boy said, "What's the matter, old man, haven't you ever done anything wild in your life?"
The old man answered, "Well yes, actually, I have. I got drunk once and had sex with a parrot. I was just wondering if you were my son."
Magicman
Oct 8, 2019
5,515
7,580
Brookhaven, MS
knotholesawmill.com
Tool Descriptions
DRILL PRESS:A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted project which you had carefully set in the corner where nothing could get to it.
WIRE WHEEL:Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, Oh......!
SKIL SAW:A portable cutting tool used to make studs too short.
PLIERS:Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
BELT SANDER:An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
HACKSAW:One of a family of cutting tools built on the Ouija board principle... It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS:Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
OXYACETYLENE TORCH:Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub out of which you want to remove a bearing race.
TABLE SAW:A large stationary power tool commonly used to launch wood projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK:Used for lowering an automobile to the ground after you have installed your new brake shoes , trapping the jack handle firmly under the bumper.
BAND SAW:A large stationary power saw primarily used by most shops to cut good aluminum sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside edge.
TWO-TON ENGINE HOIST:A tool for testing the maximum tensile strength of everything you forgot to disconnect.
PHILLIPS SCREWDRIVER:Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER:A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws and butchering your palms.
PRY BAR:A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER:A tool used to make hoses too short.
HAMMER:Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit.
UTILITY KNIFE:Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use. Fingers and thumbs often see the sharp side of this tool!
SON-OF-A-BITCH TOOL: A personal favorite!) Any handy tool that you grab and throw across the garage while yelling SON-OF-A-BITCH! at the top of your lungs. It is also, most often, the next tool that you will need.
Reactions: 6 users
Magicman
Oct 8, 2019
5,515
7,580
Brookhaven, MS
knotholesawmill.com
Employee: Excuse me sir, may I talk to you?
Boss: Sure, come on in. What can I do for you?
Employee: Well sir, as you know, I have been an employee of this prestigious firm for over ten years.
Boss: Yes.
Employee: I won't beat around the bush. Sir, I would like a raise. I currently have four companies after me and so I decided to talk to you first.
Boss: A raise? I would love to give you a raise, but this is just not the right time.
Employee: I understand your position, and I know that the current economic down turn has had a negative impact on sales, but you must also take into consideration my hard work, pro- activeness and loyalty to this company for over a decade.
Boss: Taking into account these factors, and considering I don't want to start a brain drain, I'm willing to offer you a ten percent raise and an extra five days of vacation time. How does that sound?
Employee: Great! It's a deal! Thank you, sir!
Boss: Before you go, just out of curiosity, what companies were after you?
Employee: Oh, the Electric Company, Gas Company, Water Company and the Mortgage Company!
Magicman
Oct 8, 2019
5,515
7,580
Brookhaven, MS
knotholesawmill.com
The new foreman walked into the reception area and was determined to make his mark. Seeing a man out of uniform lounging against a wall he roared"YOU, how much do you make a week?" The man replied "$500. " "Give that layabout $1000 severance, he is fired".
After the guy pocketed the money and left the foreman asked who he was. The receptionist replied " The pizza delivery".
i7win7
Feb 21, 2020
3,379
3,982
Central, IL
Movin the farm
i7win7
Feb 21, 2020
3,379
3,982
Central, IL
Picked up new water line
Magicman
Oct 8, 2019
5,515
7,580
Brookhaven, MS
knotholesawmill.com
WHEN I SAY I'M BROKE - I'M BROKE!
A little old lady answered a knock on the door one day to be
confronted by a well-dressed young man carrying a vacuum cleaner.
'Good morning,' said the young man. 'If I could take a couple minutes of your time, I would like to demonstrate the very latest in high-powered vacuum cleaners...
' 'Go away!' said the old lady. ''I'm broke and haven't got any money!'' and she proceeded to close the door.
Quick as a flash, the young man wedged his foot in the door and pushed it wide open... ''Don't be too hasty!'' he said. ''Not until you have at least seen my demonstration.''
And with that, he emptied a bucket of horse manure onto her hallway carpet.
''Now, if this vacuum cleaner does not remove all traces of this horse manure from your carpet, Madam, I will personally eat the remainder.''
The old lady stepped back and said, ''Well let me get you a fork, 'cause they cut off my electricity this morning."
4,816
A beautiful blonde goes out with a bodybuilder. Things go well and by their 4th date, she wants to take it to the 'next level'. They reach her apartment and, after a nice dinner, begin to kiss and take their clothes off. The blonde says, "Wow, what a great chest you have!"
He says, "100lbs of dynamite, babe!"
He takes off his pants and the blonde says "What massive calves you have!"
He replies, "That's 100lbs of dynamite, babe!"
He then removes his underwear and the blonde runs off screaming in fear. He rushes to put his clothes back on and chases after her. He finally catches up with her. "Why did you run away?" He pants.
She says, "With all that dynamite, I ran when I saw how short the fuse was!
