Not sure if this was a good idea or not now.
I bought a whole case of this new mystery oil OmniCron for the Kubota. You add it to your normal oil.
It advertises that when my tractor breaks down in the future it might not break as bad. It will still break down, just maybe not as bad. They had some really nice posters and cartoons explaining the numbers. I was really impressed with the cartoons but they really were not very informative. There is nothing but POSITIVE reviews to be found on it. It is true that they routinely delete bad reviews but they say it is ok to hide any negative data (I'm not sure why).
After all the horror stories of breakdowns by the people that do not use OmniCron and all the nothing but positive reviews, I broke down and bought a case.
Sure it isn't an issue for like 99.9% of tractor owners out there but if we can save just one tractor (big smile).
Now I'm holding the bottle up (getting ready to pour) and see some of the fine print at the bottom.
SOME ENGINES WILL SEIZE UP AND DIE AFTER USE - SOME ENGINES WILL LOOSE OIL PRESSURE AFTER USE - SOME ENGINES WILL START TO LEAK - IF YOU DON'T CONTINUE TO USE THIS REGULARLY SOME ENGINES WILL BREAK AND DIE - YOUR ENGINE WILL NEVER BE QUITE THE SAME AGAIN BUT PROBABLY WON"T BE WORSE
So I stopped the pour right there. My tractor already broke once and my mechanic (the guy is like a doctor) said it will not break like that again. Not sure if I dodged a bullet or not.
Would you line up to buy it?
