Do I have to junk my beloved B2800 D?
Percy
B8200D
Jul 20, 2021
Vermont
The steering column gearing has has died. Broken teeth and ball bearings.
I have tried Cross Creek, Southern Farm, Weavers Compact and All States Ag to no avail.
Does anyone have any ideas as to where I might find a salvaged column?
2,968
I believe there is a member here who sells parts for older Kubota tractors. Used but serviceable parts.
For the the life of me I can’t remember his screen name. I bet somebody will though!
5,261
Are we talking a B8200D or B2800D?
Your title says B2800D, but your profile says B8200D.
That's a good place to start in your search.....
Geared or HST?
Have your tried Kubota Tractor Corporation - Illustrated Parts List (kubotausa.com) for parts numbers you're looking for?
The person Henro was talking about is 007kubotaguy . He has older L parts, not so sure of B parts. If you see him give a thumbs up on this thread, you might be in luck.
airbiscuit
Mar 18, 2021
215
150
NW WI
I've seen a few people use the electric power steering from a Saturn Vue. They are remarkably inexpensive.
5,581
What exact tractor do you have? B8200 gear drive?
If so, I may have the gearbox. I removed from a tractor with 600 hrs or so and installed power steering.
ezriderf6c
b8200d 4x4 with bf300a and backhoe and KX-161-3st w/ steel tracks
Are you asking D2 Cat for pics of the steering assembly he has available?
yes, to see if it is like mine. Mine was working great and I took it to the dealership to replace a seal on the rear left axle and when I got it back the power steering doesn't work. It steers, but no assist. Before it was smooth and effortless like running on glass.
Chanceywd
Kubota L2501DT BH77 VIRNIG URG60-CT 1950 8N
Mar 26, 2021
607
469
central ny
It was a bit of work but I put one of those on my 1950 8n. What a difference with the arthritic shoulders! Got the control from the guy on ebay. I still have the 8n for snow plowing and firewood.
Bill
kubotasam
Apr 26, 2010
1,204
128
Alfred Maine
If it steers but no assist on a B8200 you do not have a bad gearbox. All hydraulic assist in steering is attached to the drag link.
Old_Paint
Dec 5, 2020
1,734
1,730
AL
Bill
Pretty amazing how many of those old 8N's are still around and still working just as good as any new tractor. Did you update the ignition system, or are you still running the old magneto hardware?
Oo-v-oO
2000 B7500
Oct 31, 2021
67
55
Central NH
Why wouldn't it go right back to the dealer, in that case?
3,316
The 8N didn’t have a magneto. (That would be a 2N). The 8N had points/condenser/coil ignition.
Chanceywd
Mar 26, 2021
607
469
central ny
Yes I did update that when I changed to 12 volt adding a gm alternator. Those things made it a sure starter in the winter here in upstate new york. A couple years ago I did a valve job replacing all of them. An old mechanic local to me came and ground the valves for me with one of those, I think it was a Sioux valve grinders.
Mine is a 1950 side distributor and a sherman over, under, direct too.
Bill
fsfzzz
b8200
May 4, 2022
Do u still have the gear drive for a B8200 HST ? If so how much?
