Bucket for Plowing Snow
yzinger
71
Nova Scotia, Canada
Hey OTT - has anyone experienced with somehow mounted rear blade to bucket for snow plowing purposes? Or maybe even some way to stop windrows when using the front bucket to push snow?
BX25 with a rear blower - but, on smaller snows the lil tractor can push snow pretty good but a fair amount of cleanup needed for those damn windrows.
Thanks
7,334
Thanks
I chained mine on ONE time. It didn't work real well but you may have better luck.
MINICUP28
B7610, KX-018, RTV-500, JD X758
Feb 21, 2019
106
55
COBLESKILL, NY
I have a 5' clamp-on blade on the bucket and a 5' rear snowblower. I have a very long steep downhill gravel road. I plow downhill to one side of the road and then blow the windrow away going back up.
One more trip down with the blade angled clears the road. Sometimes I angle plow going back up the other side, but it depends on the snow depth.
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,447
1,743
Kalamazoo, MI
I don't sweat the crumbs. Fabricate some end caps for the blade or get a small HLA snow pusher from Good Works Tractors for the FEL.
6,323
'windrows' are formed from excess snow when trying to push a 'huge' pile( well bigger than your bucket ),you're aking more than you should.
hard to avoid, unless you take 1/2 or 1/4 bucket's worth of snow,
easy to cleanup, move 99% of the snow,push, push,push, then zip push up the windrows ,one at a time.
you also can get windows snowblowing, same reason, same 'fixes'.
JeremyBX2200
BX2200
Aug 3, 2020
506
455
Indiana
I plowed last year with the bucket. Worked fairly well but took extra passes for cleanup.
For this winter I am building something very similar to this to try. Our winters are really hit and miss. Some require a lot of snow removal and other almost none at all.
JeremyBX2200
BX2200
Aug 3, 2020
506
455
Indiana
thats pretty neat. Thanks for posting lots of ideas there.
I will post some pics after I get it done. I just ordered some bolt on hooks for my bucket. The plan is to utilize those to secure it to the top of the bucket.
Here is where I am at so far:
mcfarmall
Sep 11, 2013
1,447
1,743
Kalamazoo, MI
