Wood Splitter: Self-contained vs Tractor Powered?
Captain13
Feb 27, 2019
520
170
Kathleen, GA
You are describing a $6K+ splitter. That is a whole different universe.
I didn’t pay 6K. It’s a Timberwolf but I got it at auction in Atlanta several years ago for a great low price and it has been a great splitter. I had two before that, both self contained. The Timberwolf is a whole different universe, though. That’s a splitting machine.
6,334
Now we are talking $7-8K plus and $10K just over the horizon....
ACDII
Oct 21, 2021
688
431
Illinois
3PT is fine IF your tractor has the output for it. If not, my B2410 doesn't, then you need a tank and PTO pump. That doubles the price of the splitter and puts it at the same cost as a self contained. My Woods BH70-x is all self contained, no need to rely on the tractors hydraulics to run the back hoe, would be the same thing if I were to get a splitter.
6,334
You might be surprised at how fast your B2410 @7GPM is with the right valve on the splitter. I posted this a few days ago:
Log Splitter Valve with Regen
ACDII
Oct 21, 2021
688
431
Illinois
That would require opening up the hydraulics and adding the lines though in order to hook it up, right now it only has the loader controls. I wouldn't even know what to look for in order to tap into the system.
6,334
Hookup is trivial. You simply put a quick coupler on the loader power beyond hose and daisy chain the splitter off that port. I ran my splitter off the loader valve on my B7200 for years before I finally added a rear outlet.
But it turns out I got the wrong hydraulic flow rate when I looked up the B2410. Its 7 GPM but 2.6 of that is split off for the PS so you only get 4.4 at the loader. That would be close to the flow on my B7200 and that was painfully slow. The valve with regen would help but you are still looking at roughly 20 seconds cycle time on a 4 x 24 cylinder. Not horrible but definitly slow.
ACDII
Oct 21, 2021
688
431
Illinois
I could probably do that on the L4060. My B2410 has been too reliable the way it is, why jinx it. I am having 2 duals installed in the rear, and could probably have Power Beyond on that one too.
6,334
The L4060 implement flow is 9,5 GPM and would run a small log splitter.
NorCalRick
MX5800 KX057-5 LP FM2572 Flail BB2572 Box SGC1072 Grapple WM WC88 Chipper
Oct 5, 2021
Mendocino County , CA
I have always used self contained. Had the Wolfe Ridge PRO-28C for a couple of years. Works fast and the log lift is a life and back saver
dgtvrpepair
L4760HSTC RTV-X1100c ZD1211L-72
Feb 10, 2020
55
30
Morrilton AR United States
I personally like my 3 point rear remote powered log splitter. I can run my l4760 at 1000 rpm and it is plenty fast and powerful. I don't have to maintain another engine. I split about 5 ricks a year. If I was selling wood I would want a self contained unit.
Springer
BX2680 LA344S EA 55" Grapple, Stump Bucket 48 Box grader, Disc Harrow
Jul 21, 2021
98
56
Tiger, GA
We had the same discussion when getting our splitter. I went with a used stand-alone.
I am glad I did since I use the bucket to kind of feed the splitter. I load it with cut logs and level the bucket to the splitter. Then I roll them out of the bucket right onto the rail. After they are split, I throw the wood into the Brinley.
Couldn't do that with a PTO set up.
Quick
B2601, LA435, BH70, LP SGC0554 Grapple, LP RB1672 Rear Blade, King Kutter 60" BB
Sep 23, 2021
146
252
St. Clair, MO.
Yep, I do kinda the same. 27 ton splitter about 1300 bucks. Transfer is level to bucket, moved and unloaded where ever ya need it at the height ya want.
alexeaton
L6060
May 5, 2021
10
Minnesota
Yep, I do kinda the same. 27 ton splitter about 1300 bucks. Transfer is level to bucket, moved and unloaded where ever ya need it at the height ya want. View attachment 69154 View attachment 69155
Having seen those pics, that seals the deal for me. I'm going to go with self-contained. I can definitely see the value of having a free tractor, and it barely costs more than PTO driven. Thx all! Alex
Springer
Jul 21, 2021
98
56
Tiger, GA
You are pushing that 27 ton ram to its limit from the looks of it. That is what I have to do this weekend. Cold weather coming and I'll need about two cords to get through winter.
Captain13
Feb 27, 2019
520
170
Kathleen, GA
Having the tractor free is key for me. I load the splits into the cage directly from the splitter and use the tractor to move the cage (liquid tote cages are what I use for storing.
6,017
re: I'm going to go with self-contained. I can definitely see the value of having a free tractor,
So if I buy a 27T splitter, I get a free tractor too ??!!!!
GREAT, sign me up... wife'd just love a 5th tractor here....
seriously though has anyone who cuts/splits more than 2-3 cords ( that's REAL cords...NOT citibot cords) , looked into 'woodprocessors', even the smaller ones ?
Quick
Sep 23, 2021
146
252
St. Clair, MO.
Most of it was from dead trees, so easier splitting. It strained a bit, but plunged right through. Got a lot done in a few days. (-:
dan_m
BX2380
Jul 9, 2020
199
94
Georgia
I have a self contained (25T cub cadet with a honda engine). It's good for another reason that I didn't see listed in any previous posts - It's easier to loan than a tractor + splitter to friends in exchange for future manual labor help on projects requiring more hands. :)
I've split sweet gum with the cub cadet - would not try that with an axe 😜. Now I have Plenty of firewood for the outdoor firepit to schmooze the loanees for help building a firewood shed or help building a bridge over a creek 🤣
