7,177
Mower coming off, oil change, and my removable LED’s on. May mount the snowblower after I service it.
Will just leave chains to do.
Just an aside and not Kubota, but Minneapolis Moline. A friend makes these for Steiner Tractor Parts. Redneck Gas gauge.
He has templates for many old, more popular makes and models. He’s sold 1,000’s to Steiner. Guys don’t use them…more for decoration
Saw my Moline parked in the driveway, and asked that I measure the gas tank so he could make some.
Figured Steiner won’t be interested since numbers are small, but I got the first 2. There is a pretty active national MM Club.
One will go to my Dad…..
Reactions: 7 users
Bmyers
May 27, 2019
3,534
4,575
Southern Illinois
We fixed a gate to the field. After that we started clearing more brush and working on drainage ditch trying to beat the rain.
I didn't get a good before picture, but if you look to the left in the picture below you can see what we were dealing with. (this picture was from last year hence the soybeans and not the corn)
This is the area after about four hours of two tractors clearing the area. Still have some more work to do, but we got a lot of brush and trees moved to the burn pile.
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,564
3,867
PEI Canada
The first 40 minutes went well and then...
  • Angry
pokey1416
Jun 24, 2020
569
868
SW Michigan
Took the loader off for the umpthient time. Washed and waxed her for winter. Went to put loader back on and fought it for over an hour 😬. Couldn’t get it to drop in the cradle on one side no matter how many times I repositioned. Finally, decided to measure the boom cylinders on both sides - over 2” difference. Then I got to looking around and saw where I caught one side when backing out. Equaled the cylinders and “bingo” went together as before. Another lesson learned 🤔
dlsmith
BX2230, LA211
Nov 15, 2018
1,322
964
Goshen, IN
Started the BX up and let it warm up for 15 minutes at high idle, backed it into the shop and got started. Changed the oil and filter, the air filter was pretty dirty, so I changed it too. Only spilled about a cup of oil on the floor, no oil change is complete without spilled oil and Oil Dri. Checked the front axle oil, trans/hydro fluid, fan belt and coolant reservoir. Fuel filters were new in the spring, so I didn't change them. Checked the air in the tires, pulled the radiator screen, blew it and the radiator out, lots of grass and crap in it. Finally, greased the FEL and MMM.
Ready for some snow pushing this winter or lawn mowing in the spring.
10,384
I got a nice white tail yesterday afternoon on my property (opening day of general rifle) and got him back to the house using the bucket. It's cheating for some but there you go. This guy is about as big as I've seen up here with a fair amount of fat on him.
Reactions: 9 users
MOOTS
MX6000
Jun 27, 2019
2,189
2,718
Canton, Georgia
Hooked up the newly acquired ballast box for some measurements for Brian at FitRite. Hosed it off and cracked a beer.
10,384
Didn't look like a big deer in the first photo but the third photo makes your tractor look small!!!
Yeah, he's a good size for up here and the 72" bucket helps to show that. I was able to get a photo of him through the scope when he was bedded down.
10,384
Talking of big, that ballast box is huge! You did really well to find those two and for such a good price. If you were nearer I'd buy the other one from you.
Are you sourcing the "top-n-tilt" from FitRite?
Ikc1990
Kubota m125x, m9000, b2710, and other equiptment
Dec 2, 2020
292
130
Vermont
Looking at buying a second tractor anyone ever own a 8560 mahindra? Or large mahindra tractor it is a 1999 pre emissions and has 1800 hrs.
  • Dislike
7,177
It fits with the new back blade on….just barely. Left the shop stool and crate there to avoid shin-scrapes…I hope.
Blower isn’t hooked to PTO yet. Chains not on the rears yet either.
Got the towering pile of pellets behind it. That stack is done by mid-January or so.
7,177
WOW!! Beautiful 10 (?) point. What, maybe 20-22" spread? Definitely in the rut, big time. Look at the neck...
Betting pretty heavy dressed weight....looks stout.
You didn't field dress him?
Where you're at, what do you have for ungulate games species; obviously whitetail, elk (?), moose (?), blacktail (?), pronghorn(?).
5,603
MOOTS
MX6000
Jun 27, 2019
2,189
2,718
Canton, Georgia
Yep, couldn’t pass them up. After some digging, this box is for an M. The smaller is for an L. There wasn’t a MX when they were made.
Yes I am, should be here Januaryish.
leveraddict
Apr 1, 2019
905
594
NEPA
I have the same blade for my BX. I can get a full level 360 deg turn on the blade and I still have decent lift height! It will serve you well.
