Winter Lighting for Plowing
4,816
Looking for some ideas for emergency lighting for when I am blowing or plowing snow near the read, or if I have to go into the roadway. I have been looking at LED beacons, strips, and small button mounts, about the size of a quarter. Not looking to break the bank, but to have enough lighting to keep everyone safe. I learned today about a site that sells all the strobes that are used on emergency vehicles ( https://www.strobesnmore.com ) and they have some very interesting products, but not wanting to reinvent the wheel, what are you presently using?
ve9aa
Apr 11, 2021
1,202
982
NB, Canada
I bought the Nilight lightbar and 2 spots, kit on Amazon for around $100.
I had to buy 2 x 3" square ubolts and fashion up a couple simple brackets (easy peasy)
similar to this one NILIGHT
I also added a multicolour, multi LED, magentic mount top light which has 15 flash patterns.
SIMIlar to this one flash/strobe (the toplight plugs into the "cigarette lighter" and the Nilight kit I plugged into the left rear fender 20a accessory wire intended for lighting. I put the switch in the hole by the loader valve stick.
I haven't had it a year yet, so no snowblowing, but it lights up the yard like the daytime
so I think it'll be fine.
ravensview
bx23slb
Nov 18, 2019
67
14
U.P.,MI,USA
I have a flashing yellow strobe with a strong magnetic mount on the bottom , it plugs into the 12 volt socket and has an inline switch, I don’t remember where I got it from though, I think it was about 50.00 or so, it’s meant for going on the top of a vehicle for construction work
5,194
Dusty - I have a go into the road a bit.
Besides my added LED’s on the ROP’s for lighting/vision, I changed the hazards to LED. I think they helped greatly over OEM bulbs.
River19
B2601, RB1560, BB1260 and BX2830 blower
Sep 10, 2020
327
508
NH/VT NEK
I went with the products from ROPSLights.com in Canada and can't say enough good things about them.
3,302
OK so are you looking for warning lights, or light to see by, just so we are clear. Everybody has covered what I was going to, so take your pick my friend,, 100 bucks will get you just about anything you need :)
4,816
I am looking for warning lights. I have enough lighting on my tractor without adding additional. thanks
4,899
It doesn't matter how well lit up your tractor is,sadly, while odds are small, someone will NOT see the million candlepower of flashing lights and hit you......
gets worse every year, more and more IDIOT drivers on the roads.....
3,316
Don't really need those, but I may buy them, just because! 😁
It’d make a heck of a back-up light for the pickup truck, heh?
