Better than hauling buckets
JeremyBX2200
BX2200
Aug 3, 2020
506
455
Indiana
Some of you might have seen where I used my BX2200 to tear apart my old camper.
We are planting trees and bushes around the property in areas without access to water. I saved the fresh water tank from the old camper and clamped a piece of hose to it. That way I can just haul it around to water stuff instead of carrying buckets.
Not really a "Tractor" project, except that I use the cargo tray on the back of the BX2200 to haul around the 35 gallon water tank. Version 2 will have the tank on a pallet with a 12v pump using a 3pt carry all......or at least that is what I am thinking.
Reactions: 6 users
3,069
necessity is the mother of invention! Well done!
Mlarv
BX23S
Jan 19, 2020
227
179
Crossville TN
I use a 25 gallon sprayer I bought from Rural King to do the same thing. I have mine in the back of my Side Kick. I just put a boom sprayer on it so I can spray weed and feed etc on my lawn.
ve9aa
Apr 11, 2021
1,193
972
NB, Canada
Ingenious!
3,577
Deja vu.
Back in ancient times, my first "tractor" on the land in the high country was a Suzuki 125 quad (it was orange also) with a small dump trailer.
My AC guy was dumping a bunch of freon cans so I grabbed three.
I cut both ends off one, & one end off the other two, then welded them all together.
I added a gas tank filler neck & cap, a drain valve & hose, and some "feet".
Also painted it orange. :)
We used it on the quad for many years watering plants.
Goz63
Kubota L2501, LA525 loader, QH15,Land Pride RCR1860, BB2560, SGC0660, forks
Jun 19, 2021
299
349
Mississippi
Great idea. Moving water can be a pain for sure.
3,399
I love the automatic water dispensing feature, and do realize you had to get off the tractor once that afternoon to take the picture! :ROFLMAO:
troverman
Kubota M4D-071 and Kubota ZD-1211-72
Jun 9, 2015
1,187
268
NH
Nice! I have a 275 gallon water tote, but its over 2,000lbs filled with water and I just carry it in the back of my truck.
zload
B2400HSD/47 John Deere Model M
Apr 14, 2015
91
FL
I use a 12v "ATV style" 35 gallon tank sprayer that I inherited from my dad in a similar fashion, utilized his truck hitch cargo hauler with a 3 pt 2" receiver hitch. The sprayer originally had 2 arms/3 spray nozzles to spray horizontally but I adapted it so I could spray at 2 different vertical levels for my corn or back to horizontal if needed. I could lift it high enough to spray corn at the 4' - 5' level. Typically only an acre or so of corn but way faster than walking with a backpack sprayer, especailly in late May/early June. I skipped a row between every 2 rows of corn so I would be able to spray both rows by changing direction given that the spray nozzle bracket was only on one side.
Also used it to haul water for irrigation needs and I can connect a hose/spray wand for spot treatment as needed.
JeremyBX2200
BX2200
Aug 3, 2020
506
455
Indiana
Work smarter, not harder!!!
Sounds like it turned in to a pretty useful tool.
