kdpearson
Kubota L345DT, Kubota M4500DT, International 544, Ford 3000, 1949 8N Ford
May 5, 2015
Albany, OR
I just installed the flywheel, clutch, and pressure plate on the S2600 (6 cylinder Kubota diesel engine) to install in my M4500DT. Also painted the starter and front axle (might as well paint it while I have the tractor separated).
7,075
Not much.
Did a little more driveway dressing with the box blade and did some very expensive wheelbarrow work part...
I’m VERY okay with the expensive wheelbarrow work part of the equation......[emoji3]
johnjk
Apr 13, 2017
1,688
1,873
West Mansfield, OH
Did a bit of mowing and brush cut the tree line back. Got tired of being caught by olives, wild rose and blackberry. Oh and found this bigger in my path so I relocated him back in the swamp
7,075
John - little snapping turtle?
After a couple encounters with those BIG guys as a kid, fixed me from swimming in ponds and some rivers....we didn’t have man-made swimming pools much in my neck of the woods....[emoji15]
MOOTS
MX6000
Jun 27, 2019
2,189
2,716
Canton, Georgia
Bit of a tune up on this old girl. She will be sold and a B2650 with FEL will be purchased.
JohnDB
M4500DT with FEL, back blade, Someca K28 hay mower, drag broom, post driver
Jun 9, 2018
473
107
NZ
I puckered. I puckered good. Low wheel on a side hill sank. Couldn't reverse out so I dropped the FEL and used it as a skid and ploughed on. If I think of it tomorrow I'll get a photo :eek:
Something like this? :eek:
David Page
Jun 25, 2013
393
84
Dexter, ME
After 6 months of setting, I put a battery back in the Tractor fired it up and moved it around the garden to see how things worked. Most of the yard and woods are wet with frost coming out of the ground to do anything. BUT it sounded good.
johnjk
Apr 13, 2017
1,688
1,873
West Mansfield, OH
No it was a young red-eared slider. We have snappers back in the big swamp area. I use a shovel to move those. Hopefully getting a pond put in once this corona stuff ends.
3,678
If you’d take/post those pics right-side-up that tractor might not roll-over... LOLOLOLOL:D
highonrunning90
Eastern Maine, USA
Using the Woodmaxx 8M for the first time on the B2650. 3 hours of cutting brush and limbs follow d by 30min of chipping..
What a beast of a machine! Fed a couple of 5" logs to see what it could handle..took the whole thing without a second thought..stalled out at 6" log. That's fine by me I'll burn anything 5" and bigger.
75hrs in
Sent from my Pixel 3a using Tapatalk
MOOTS
MX6000
Jun 27, 2019
2,189
2,716
Canton, Georgia
Oh man, not sure if I could do it she's a beauty.
Indeed she is. Logged many a hours in that seat. But could use a FEL and a grapple on the new property.
I did do a bit of work with the boom pole this evening, pulling a few fell trees to the burn pile. She’s a worker for sure.
Fordtech86
L3200
Aug 7, 2018
4,966
5,916
Pineville,LA
75hrs in
Please pardon my ignorance, but what it the thing hanging off the back of the cab?
