Have a cat 2 implement I need to convert to cat 1. Are there cat 1 pins available that have the cat2 size thread?
Understood, just not a fan of using bushings in a high stress area. This for the cat 2 size Titan ballast box, so a lot of weight.Usually the pins go through a plain bore in the implement and are secured with nuts. If that is the case just bush a Cat 1 pin up to Cat 2 hole size and secure with a Cat 1 nut.
I found this on TractorByNet -- P/N HII20-0034Have a cat 2 implement I need to convert to cat 1. Are there cat 1 pins available that have the cat2 size thread?
Excellent! Thank you very much!I found this on TractorByNet -- P/N HII20-0034
Even found on Amazon
Cat 2 thread with a Cat 1 pin
