Cat 1 pin with Cat 2 thread size
Dwight Bremer
L4060 HSTC, LA805, L2195A, BH92, .5TBB, PF, 12K TAT,
May 16, 2021
75
59
Hardwick, MN
Have a cat 2 implement I need to convert to cat 1. Are there cat 1 pins available that have the cat2 size thread?
4,473
Usually the pins go through a plain bore in the implement and are secured with nuts. If that is the case just bush a Cat 1 pin up to Cat 2 hole size and secure with a Cat 1 nut.
i7win7
Feb 21, 2020
3,379
3,982
Central, IL
A machine shop could turn down the cat2 pin to cat1 size
Dwight Bremer
May 16, 2021
75
59
Hardwick, MN
Understood, just not a fan of using bushings in a high stress area. This for the cat 2 size Titan ballast box, so a lot of weight.
Dwight Bremer
May 16, 2021
75
59
Hardwick, MN
I like the turn down in a lathe approach, just thought there might be pins manufactured that way.
4,899
hmm... 'lot of weight'.... will your tractor and liftarms, etc. handle the 'lot of weight' ?
if the smaller pins do break, replace arms with CAT 2 arms ?
Dwight Bremer
May 16, 2021
75
59
Hardwick, MN
The L4060hstc 3-point lift capacity at 24 in. behind lift point is 2760 pounds so my 'Lot of weight' (around 1200 pounds) should be well within prescribed design parameters.
I do like you suggestion about the Cat 2 arms, though.(y)
