Securing Pitman Arm to Steering Box - This doesn't look right
wendol
L3800 HST
Feb 5, 2014
202
45
North Tx
As I was greasing the tractor this morning, couldn't help but notice the bolt that holds the pitman arm to the steering box, appears to have backed off.
What is the process of tightening this back the original specs.......and what are the specs??
Thanks for any/all help.
ken erickson
Nov 21, 2010
1,413
2,631
Waupaca Wisconsin
I had thought the same when I took delivery of my L2501. The dealer's service tech was at my house for a tie rod related issue and and checked the nut and said this is a normal condition. IMG_4336.JPG
3,075
The shaft looks slightly tapered so the nut only has to pull it up a small amount to get a tight fit
Captain13
Feb 27, 2019
523
171
Kathleen, GA
Correct. The Pitman arm will not go all the way up the taper. Good point, Russell.
4,193
