LX3310 First Regen at 15.5 hours?
Jhtractor
2021 LX3310, LA535, RTR1258 tiller, QH10, BB1260, LX2963, PF1242, RCK60
Apr 23, 2021
34
Wisconsin
Using my new LX3310 with the FEL and box blade to grade some dirt. Saw the regen light flashing tonight and it ran through the first regen. Kept the RPM up and kept working. Could smell the filter burning during the process that took about 15 minutes and then the light went off. Wondering if I am babying the RPMs too much with the new machine and should just work it harder?
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,140
139
Hardisty, Alberta
Regens are like babies, the first one comes anytime but from then they take longer!
ItBmine
B2620, RTV-X1100C
Jan 21, 2014
1,376
382
That, and you don't know how much idling it was doing at your dealer before you took delivery.
PaulL
2,441
1,365
NZ
I'd also guess you're babying it too much. My view is that tractors are made to run at PTO revs, and if you're using a PTO implement you have to run it at PTO revs. If you run it there, not so much regen.
Having said that, many on here insist that tractors need a break in period. I haven't quite worked out how you are supposed to use PTO driven implements during that time.
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,357
1,785
Western MT
It’s probably going to be artificial to keep the RPMs up high enough doing loader work. Well, at least I usually don’t run high RPMs when I am.
You can either keep the RPMs high or have a regen. As others have noted, regens are a function of how hard the tractor is working with lower RPMs and lower temperatures causing more regens. It shouldn’t be an issue if the regens always complete.
jkrez
Gr2120, LX3310, bh77 hoe, 64 inch commercial snow blower, landpride pallet forks
Apr 16, 2021
85
84
Berks County PA
I just had a regen on my Lx3310 at 13.8 hours. It took me by surprise as I normally just run full bore. I just kept working as you and about 15 minutes the light was out.
Snowman7
May 20, 2020
367
258
Boyne Falls, MI.
16 hrs was my first and then at 32 for the second. I am at 48 now and anticipating the third. I am mainly mowing at 2300-2350
AlbertH
LX3310, LA535, MMM, Front End Snow blower, Scraper box, BX52 Wallenstein Chipper
Feb 15, 2021
Ontario
I have 50 hours on my LX3310, pretty much all hours at full throttle mowing with a 72” mmm. I have not seen the Regen light come on. Yesterday I noticed black carbon accumulation on the left side of the mower deck on on the front tire and rims.
I assume this is from the regeneration? Has anyone else seen this while working the tractor. Thanks
Jchonline
602
Red Feather Lakes, CO
You havent seen one because you are running it hot enough that you aren’t accumulating any soot in the DPF.
Jchonline
602
The lower you run the rpm overall, the more often it will regen. What I do is split the difference. I run M62 at about 2000 most of the time If I dont need PTO rpm. I am getting a regen every 50 Or so hours. The M7060 is mowing most of the time at PTO rpm, I don’t think I have noticed one at all.
