BX23S Loose Throttle
goldenpsp
BX 23S
Nov 25, 2017
69
Baltimore MD
Hey all,
Out of the blue the throttle on my BX23s has just loosened up. Basically it just doesn't stay in place. If I throttle up it just drops down to idle. If I bungie it in place it runs fine. I haven't had time to follow the throttle linkage to see how it works, but I figured I'd at least ask here in the meantime in case someone else has already dealt with this.
Thanks
7,305
Just going by memory, there's a nut with another lock nut(?) in the linkage that causes this. Follow the linkage and you'll find it/them.
Been a common problem with the BX's. Many posts here on OTT about the same thing.
Seems like many have replaced one/both with nyloc nuts.
Crash277
BX23S
Jan 17, 2021
844
623
your memory is correct.
on my 2020 23s, i had to adjust it quite a few times within the first 50 hrs. hasnt come loose in a while now. pop off your battery cover, and you can access the bottom of the lever relatively easily
Crash277
BX23S
Jan 17, 2021
844
623
The Plunk
BX23S
Nov 16, 2021
31
Western PA
When I got mine it was super tight to even move the throttle. There’s a lock nut under behind it. You can loosen the lock nut and adjust and then tighten it back up. Easy fix.
