Carburetor icing can be a problem with propane. There are pluses and minus's for all fuels. The only fuel that is without issues is electric......... oh wait, the power has gone out, so your electric generator isn't going to generate electricity.
At that temperature you are getting close to the boiling point of propane (-44F). I wonder how much pressure you would lose and if the tank could 'boil' enough vapor volume to supply a big genset.Depending on how cold of temperatures you see in the dead of winter, a propane generator is more likely to start at -20f than a diesel if something goes wrong with the glow plugs or heater.
im running a 14kw whole house genny at my place. it is hooked to a 500gal propane tank.What are your opinions on propane vs diesel for home backup generators? We have a 500 gallon propane tank and could upgrade to 1000 gallons. Looking for ~14 kW. Seems that diesel engines use less (volume) of fuel and would be cheaper to operate. Not sure about the long term prospects for propane or diesel.
Kubota makes a generator in the power range I am looking for.
Thanks in advance for your advice.![]()
Kubota 14kW Diesel Generator GL Series | GL14000
Get Norwall’s Price—14kW Diesel Generator. Exceptional Power & Compact Design. D902 3-Cylinder Engine, Easy One Side Maintenance, and Free Shippingwww.norwall.com
Dont be dissin Da Burgh"The Paris of Appalachia" Now that's funny and i don't care who you are!!
Skeets, No Way, I love the P'burg....... But I've spent time there.Dont be dissin Da Burgh
Bury the propane tank and line so that only a short piece of line is out of the ground right at the generator.At that temperature you are getting close to the boiling point of propane (-44F). I wonder how much pressure you would lose and if the tank could 'boil' enough vapor volume to supply a big genset.
I was going to put in a 500 gallon in ground propane tank, until I learned from the insurance companies home inspection, that there is a surcharge for in ground propane tanks. It all boils down to maintenance or lack of concerning the anode bags. They need to be inspected yearly, and they have to be dug up to be inspected, so many people don't do it on a regular basis. Then the tank will rust out, and there is the possibility of a gas leak and explosion, so I was told. Don't know if that is the true facts, or it is just one more item that they use to jack up the premium.Bury the propane tank and line so that only a short piece of line is out of the ground right at the generator.
When we bought our current house, I believed that to. However, it’s not really true. Most of the companies in the area that have reasonable prices always have reasonable prices. That means, you only have to get one to come out and swap the tank and pump from the old tank to the new tank. That’s what we did, and didn’t have to spend the money on a tank.Once you have company A's tank in the ground no one else will fill it. You are at the pricing mercy of your company. Buying your own frees you to shop.
That may be. I have a friend in town who had a 1000 gallon inground tank installed by a propane supplier. When he realized he was getting hosed he tried to get them to remove it. They wanted him to pay for all the costs of removal. Then he read his contract. Yep, he is on the hook for it.When we bought our current house, I believed that to. However, it’s not really true. Most of the companies in the area that have reasonable prices always have reasonable prices. That means, you only have to get one to come out and swap the tank and pump from the old tank to the new tank. That’s what we did, and didn’t have to spend the money on a tank.
If the current company decides to go high, we simply call the next one to do the same process. It’s really unbelievably easy once you do it once and understand the process. Btw, we are still happy with our company and only had to do it once. The average price is about half what the old larger company charged.
Btw, I have an above ground tank which would be far simpler of course.That may be. I have a friend in town who had a 1000 gallon inground tank installed by a propane supplier. When he realized he was getting hosed he tried to get them to remove it. They wanted him to pay for all the costs of removal. Then he read his contract. Yep, he is on the hook for it.
During an ice storm neither diesel trucks nor propane trucks are moving so we better have ample fuel to last thru the crisis. We need to make a decision on which genny will last the longest on the same amount of fuel while running an entire house. And how much fuel capacity should we buy in the first place.Thanks for all the advice and info. I am leaning toward a diesel generator. From another site/forum, the consensus is that diesel would be easier to find if things go south.
Propane is cleaner/less maintenance and automatic, but uses more volume of fuel. Propane prices are going up significantly in the future, supplies are likely decreasing.
I have a pre-Y2K Generac 4 kW gas generator. I take care of it and it runs like new.
Standby: Some electrician on here is going to jump all over you, to explain you how treacherous this is!I went cheap and bought a large gas powered generator. Have a 30 amp plug in in the garage. Made a cable with male plug ins on each side. Generator has a 30 amp connector. I plug in my generator (have to shut off breaker to the house in case power is restored) and it back feeds to the entire house. Just have to watch what I run at times.
Oh yeah, I get jumped on many times for telling folks about this. Oh well, works for me and others doing the same thing.Standby: Some electrician on here is going to jump all over you, to explain you how treacherous this is!
I have been doing the same.......for 60+ years!![]()
Yep, some people are cavalier with other people's livesStandby: Some electrician on here is going to jump all over you, to explain you how treacherous this is!
