In the thread about changing the BX 3-point to position control, someone mentioned adding an indicator instead. I decided to add a pointer in the slot intended for the optional rear remotes. Today, I got the pointer made and mounted. The pointer is attached to a delrin plastic piece that pivots on an aluminum post. It will be moved by a sleeved cable (choke cable) hooked to the 3-point rocker shaft arm.
