Tractor PTO shaft cover made with orbit 4" sprinkler popup head
jkk04
kubota l1500, JD 410 backhoe,MF 30 tractor, IH TD14 142, BCS 715 tiller
Jan 9, 2017
79
PLYMOUTH CA
Have you ever thought about making PVC or Rubber PTO shaft cover?
Hope, this video answers the question.
The reason I made the cover(cap) is to keep the PTO shaft clean (I want grease film in mine before I put it on) and it keeps the shaft from rusting, dusting when I'm not using it.
John
2,543
Excellent "fit and fix"
Before I got to place in the video of your use of heat ... I was thinking a good heat gun would soften that plastic up to make a perfect fit!
Well done
jkk04
Jan 9, 2017
79
PLYMOUTH CA
Well done
Yes!!! Heat gun is much better than propane Burner that I don't have...^^LOL^^
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,410
1,691
Kalamazoo, MI
You wouldn't believe the number of PTO cover ideas I've seen since spending $20 on a pair of OEM soft plastic covers!
