Hydraulic lines reversed
Larry Bowman
Kubota 2600dt
Aug 6, 2021
Fulton Ks
I got the in and out reversed from the loader valve to the block under the seat. Now the three point won't raise with the lever but if u use the loader valve sideways like u gonna dump the bucket the three point will raise up
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,140
139
Hardisty, Alberta
You most likely have the PB and T lines reversed ( power beyond and tank)
ve9aa
Apr 11, 2021
1,202
982
NB, Canada
Is this a trick question?:geek:
2,968
First question, did you put them back the way you know they should be?
If so, then it appears you’re saying things work different now after you made that mistake, and corrected it. Is this so?
Larry Bowman
Kubota 2600dt
Aug 6, 2021
Fulton Ks
Yes now to raise the three point leave the three point handle in the raise position.then take the loader and move left or right to raise the three point
torch
Jun 10, 2016
2,619
869
Muskoka, Ont.
As eserv noted: it sounds like you have the loader T(ank) and P(ower)B(eyond) connections reversed at the loader control valve. Is the line back to the tank (sump) flowing constantly when the loader valve is in the neutral position? The loader valve should only send fluid to the tank when the lever is operated. In neutral the loader valve should send fluid through the PB port to the 3ph. When the loader is operated, the loader valve should cut off flow to the PB port and send any excess to the tank port.
