I have an M4030su that I am unable to get to start. It had been starting with no problems when it starting slowly spinning down and stopped. I attempted to start it a few times with the same results, it would run a little and then slowly shut down. I had had a similar issue with trash in the fuel line before so I blew out the fuel lines up to the injector pump until fuel was running freely. After doing this I tried to start it again and after turning over a few times it started, but immediately ran to full throttle. I quickly grabbed the throttle lever to slow it down but it had no effect. I then grabbed the kill button and tried to pull it out to kill the fuel but it would not move and when I tried to manually turn the engine cut-off lever on the injector pump it was stuck. I had to use a screwdriver with enough force to make the fuel cutoff turn and finally kill the engine. From that point forward it would no start. I loosed a couple of injectors and spun the engine over got no results.
I am concerned the injector pump is bad and that I may need to rebuild or replace it. Can someone recommend a good place to get a pump rebuilt, or that I might order from?
Thanks!
Thanks!
