load distribution on FEL chain hooks
barndoor
LX2610
Mar 10, 2021
30
10
Santa Cruz County, California
brand new tractor user here, just took delivery of my LX2610! I'm about to put two of Ken's chain hook/clevis combos on the bucket, in line with the cylinders. I've chosen to not do a center hook/clevis (yet) wanting to avoid potentially bending the bucket. If I need to pull or lift something heavy I'll use a shorter piece of chain between the two bucket hooks, and then hook another chain to the center of that, distributing the load more evenly, which brings me to my question: Should I connect to the short chain with a hook (fixed) or some kind of slip connection? It seems to me that if I hook to the chain and pull unevenly on something only one of the bucket hooks will really take the force. If that was a slip connection wouldn't it distribute the load a little more evenly? Or cause more problems I'm not thinking of, having never done it?
jkrez
Gr2120, LX3310, bh77 hoe, 64 inch commercial snow blower, landpride pallet forks
Apr 16, 2021
85
84
Berks County PA
I bought the same hooks. I am thinking that doing as you say with chain hooked to both hooks and then hooked toward the center would be best?
barndoor
LX2610
Mar 10, 2021
30
10
Keep in mind, I have no idea what what I'm talking about when it comes to chain and tractors. But I can see a scenario in which you are dragging a log out, and the log rolls to one side, and if the chain is attached fixed in the center of the short chain with a hook one leg of the short chain likely goes slack, putting all the force on one of the bucket hooks.
Of course I'd probably tackle this job with the draw bar instead of the bucket, but the hooks are going to be there, and I just wanted to hear how more experienced tractor operators are using them with a shorter chain to achieve a center pull. Perhaps this imaginary scenario I'm thinking of really doesn't happen...
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,447
1,743
Kalamazoo, MI
I don't lift with my material bucket. All lifting is done with the pallet forks. I have a 1/2" 12,000 lb rated D-ring welded in the center of the pallet fork frame for such jobs. I can use the D-ring with or without the forks on the frame. It also provides a place for a strap or chain to secure irregular shaped loads on the forks and a tie down point for transport.
19thSF
B2650, loader, MMM, pallet forks, tooth bar, rear blade, JD 318 w/plow, JD X350
Mar 1, 2020
408
124
Glendale, Rhode Island
Although I have hooks on my bucket, I only use them for light lifts. From a technical viewpoint, the idea is to avoid a side load on the lifting frame. So have the chain, or lifting sling lined up with frame to the extent possible. The key phrase is an "evenly distributed load".
Usedb3030
b3030, bh77, 5 ft brush hog
Jun 6, 2020
Oregon, United States
clevis rings inside the bucket at lift arms. chain
Ken bolt on hooks with the clevis bracket inside the bucket. Hang the choker or log tongs on a loop of 1/4 inch chain (with B/A keepers). Do not worry much about unequal load for arms. A large oak butt sways enough when lifted..try to avoid getting the bucket load very high. I drag them till i can get to smooth level area
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,945
2,340
Western MT
I use a short piece about 44 inches (bridle) to go between my bucket hooks that are inline with the cylinders. I covered that bridle with tubular nylon with a gap in the center and zip tied them in place to keep from causing unnecessary paint damage to my bucket.
I use a couple of chain links between a regular hook that attaches to the “bridle” and a slip hook to attach straps etc. A slip hook will slip since they are designed to do that which could unevenly load the cylinders. If I want to use chain, I attach the regular type hook to my bridle.
Goz63
Kubota L2501, LA525 loader, QH15,Land Pride RCR1860, BB2560, SGC0660, forks
Jun 19, 2021
299
349
Mississippi
Jim I am a visual guy. Can you post a picture. I am contemplating putting something on the bucket. One hook in center, one on each end or loops in the bucket. Not sure yet.
jimh406
Jan 29, 2021
2,945
2,340
Western MT
I hope this is an ok picture. I probably could have made it a little longer to leave more room for the hook, but it works great.
Obviously, it is easily removable since it’s only links in the hooks. I thought of this approach to avoid a center hook since I heard about buckets being bent from the pressure at a center hook.
Goz63
Jun 19, 2021
299
349
Mississippi
Thanks Jim. I like that set up. Hope you don’t mind if I copy it. Did you weld your hooks or bolt on?
lynnmor
B2601-1
May 3, 2021
1,798
1,605
Red Lion
With the chain that short, you will have considerable tension pulling the hooks towards each other.
Magicman
Oct 8, 2019
6,057
9,535
Brookhaven, MS
knotholesawmill.com
I continue to be well pleased with my decision to attach my hooks to the side of the bucket with a couple of links of Grade70 chain and Grade 8 bolts. It gives the hooks the ability to swivel when necessary.
This was yesterday loading my Bushhog on my trailer for repairs. (The rear wheels had been removed)
The hooks on the side keeps the bucket out of the way.
Goz63
Jun 19, 2021
299
349
Mississippi
Always a trade-off. Longer chains give you less potential lift height.
I would use something else like a grapple or forks if it was going to be real heavy load. For pulling if it again was a bigger load would use the rear tow bar. Just looking to get more use out of the bucket and on occasion not have to switch front end implements. So this set up looks good. I may go to the Clovis loops and go that rout. Not sure yet but like the concept.
jimh406
Jan 29, 2021
2,945
2,340
Western MT
That’s why I did this, too. It’s nice to leave the bucket on to lift one or two things, and I went with the hooks because I only have to slide the chain in the hook, and as I said, I can use a strap on the slide type hook with my “bridle”.
Bri-Guy-GA
Kubota BX1880
Sep 10, 2020
207
161
Villa Rica, GA
What if you have a single lift cylinder as is the case with my BX. Have 2 Ken's hooks on the way. Figured I would put that inboard of the quick attach arms a few inches.
jimh406
Jan 29, 2021
2,945
2,340
Western MT
I think that would be ok if you can't put them in line with the arms.
4,203
I’m thinking that using a chain as a “bridle” will expose the bridle-chain to considerably more stress than it would in simple tension. If/When it snaps it may “sling” violently releasing links as projectiles. It also places angular stress on the hooks…not their strongest position…and can rip the welds more easily than straight pulls.
To prevent bending the bucket with a center-clevis or center-hook, a reinforcement angle or plate should be welded (or bolted as a second choice) along the top of the bucket-lip behind the rolled edge. Placing the clevis or hook onto the plate by welding will thoroughly strengthen the entire assembly.
I’m not an engineer but this idea of a short chain as a bridle should be carefully re-evaluated, IMO.
