Just entering this for the forum archive should anyone go searching in the future. I couldn't find much here when I searched.
If you have a B2601 with dealer installed 3rd function kit "B1653" it has an on/off switch on the loader joystick. It will fail in short order if it gets wet. The part number for this switch is 7J056-84152 (superseded 7J056-84150). Kubota charges $150 for it. The switch is a $20 "NKK YB-16w". It is a latching SPDT microswitch. Incidentally, NKK makes a spring loaded guarded cover for this switch which would be handy, part# NKK AT4175, but it's difficult to get.
My dealer dropped off a new switch to me since it's under warranty, a quick 5 minute job to swap it out, but im sure I will have this problem again soon.
The switch has a 4 pin plug at the joystick base, with 4 wires going to the switch. The two wires that arm the system are the yellow w/red, and red w/black. When this dies again, I will cut the switch off, discard the two wires for the led light, and install a quality toggle switch to the ones mentioned above. I'll move it to the plastic fender trim where the levers are.
casting this off to the forum archive
this is the micro switch guts broken from its upper half
new switch with its plug
switch component
switch component
