Dim control panel KX41-3v
oldnslow
L3901, JD2020, KX121-3, Torro 5&7 gang reel mower
Jul 24, 2021
15
I bought a KX41-3V and the control / instrument panel works but its so dim that its VERY hard to read even with a flashlight. I remover it and dissembled it to see if it could be fixed. Under the clear view panel there is a white paper. The white paper has a brownish wrinkled film over it. At one time could have been glued. So I have tried it white side up(no go). Brown side up sill VERY dim.
Questions: can it be fixed? Why so dim? Any suggestions?
At this point I'm considering just installing Temp and oil gage.
Thank you ahead of time for considering!!!!
Sorry for the delay. life.
The last picture shows the strip that the info is displayed thru. All the date is there you just cant read it. Even with a flashlight you cannot see it all.
Checked with local dealer and was told they are only sold as a complete replacement item.
Any suggestions. I really need the info for safe operations. HELP Thanks
Jim L.
871
172
The display for that machine depends on its serial number.
It could be dirty contacts; or, some displays lose brightness over time.
Get us the machine serial number, then we can look up the display part number, and get a ballpark price on replacement.
oldnslow
Jul 24, 2021
15
Will do
Jim L.
871
172
Sorry, not good news.
The meter itself for that S/N was a Kubota RB237-53113. That was superseded by RB449-53113, new was $983. That's been superseded by RB449-53114 now priced around $1,250.
If this part had been in a recall, I would think the deadline is long past.
The brownish wrinkled film is likely polarizing. Can that be fixed? Likely it would take a very specialized shop that handles LCD displays.
oldnslow
Jul 24, 2021
15
Understand Thanks for the info
I guess the best thing I can do at this point is try to figure out how to install a water temp and oil pressure gage. The cost if replacing it is out of my reach.
Any suggestions on the install?
5,897
If you've got some time to kill....
I'd try to find the OEM that made the LCD for the OEM that made the dash for Kubota. It might be possible to buy the LCD unit. Hopefully the numbers on the PCB and LCD will help in finding who actually made it.
I've done this in the past for client's 'special' equipment and there are websites that have 'weird' ( aka surplus ) LCD modules. Yes it WILL take time and effort to locate, but would be the best solution.
Maybe locate a Kubota machine scrapyard and buy a used display ? K made a LOT of those machines...they have to 'end up' somewhere, so again...use the Internet and Google.
If it was mine, I'd just make a new display, $30 worth of parts, cut code, install however I do have 5 decades of making stuff like this so option 'a' or 'b' will be better for you.
If things were normal, you might get a colleg kid needing a term project to make one. Actually a GREAT project as it's different than the usual stuff profs see....
oldnslow
Jul 24, 2021
15
Super idea,, we have a local VOTEC school,, I will check with them Thanks
3,301
Actually, if repair is beyond their interest or abilities, it could be a cool project for one or a group of the students, to design a replacement setup, using analog gages in place of the LCD display, for the two functions you mentioned that are important to you.
oldnslow
Jul 24, 2021
15
The last 2 pictures shows this brown film / tape... Anyone know what it is or have a source?
Would like to replace it... Thanks for all the help in the past and now........
imarobot
5740HSTC-3, FDR2584 Finish Mower, BH92 Backhoe, L2195A Snowblower, LA854 FEL, +
Apr 18, 2025
279
166
NH
Not sure, but it looks like Kapton tape. This is lke a mylar high temp resistant tape often used on electronic stuff for insulating circuit boards.
Amazon.com : kapton tape
oldnslow
Jul 24, 2021
15
just a update, ordered a screen from eBay ($189, China, carlcddosplay) arrived today. I installed it and it worked great. The reason I went this way I just got tired of chasing my tail... Some others were selling screen for twice the price. If anyone has the same problem I would be glad to share some info with you.
oldnslow
Jul 24, 2021
15
Sorry for got to say " Thanks for all the help". A special thanks to imarobot for sending the kapton tape, it was used and made a big difference, I owe you
