7,007
400 hour service yesterday. not much drama other than the owners/operator manual has some miss prints failing to show (truly) where the drain plugs are for the hydraulic oil. Intuition told me that there should be a drainplug on the lower halves of the gear case housing. I found them. Book doesn't specify where they are.
Fresh SUDT2 does seem to have quieted the HST whine a bit. Maybe wishful thinking and possibly too early to tell for sure.
Picked up some fresh orange spray paint from TSC and touched up a spot on the deck. All good to go now.
ctfjr
L3800HST
Dec 7, 2009
1,982
2,541
central ct
Today I cobbled together a pressure gauge setup for the hydraulics. Measured my max pressure at just over 2300psi. I have some shims and want to get it closer to 2500psi.
Does anyone know the approximate increase by adding .1 (mm? in?) Kubota shim?
Crash277
BX23S
Jan 17, 2021
844
623
Been a while since I’ve got to post. Been crazy busy. Not on the bota though. Lent it to a friend, getting it back at the end of the week so I can finally finish my driveway extension.
6,761
Sorted out the good from bad wood in a semi-rotten trellis/swing thing mother-in-law wanted gone. Bad wood went to the back of the pickup to be hauled off. Good wood went to the shed rafters. Usually that involves stepladder and throwing it up board by board. Was kind of nice to put a bucket of lumber just enough under the joists to allow unloading, climb up in the rafters once (instead of 50 times), and pick the pieces out of the bucket without leaving the rafters until done.
ctfjr
L3800HST
Dec 7, 2009
1,982
2,541
central ct
Got my Sicma tiller in from EA. Still have a month or so before I can redo the lawn with it. So for now it's resting in the basement.
Reactions: 6 users
7,007
Another soil line replacement with power mole pull. Not a very informative pic taken from the cab of the excavator. I didn't really have time to fool around taking any interesting pictures with the ladder leaning up against the road while traffic whizzed by 🤬. The sides of the hole were collapsing and a utility pole was 3 feet to the left of the hole. 😰
NHSleddog
B2650
Dec 19, 2019
2,144
1,839
Southern, NH
I noticed the same. I do my hydro and oil at the same time on the 200's and you can hear the motor is quieter and the HST is quieter afterward. I'm not sure at what point it reverts back but it does - lol.
L35
Jun 13, 2010
710
829
CT
I walked past mine, looked at it stuffed into the corner of the garage sitting on its battery tender. Haven’t used it since the beginning of April, screwed up my shoulder and needed surgery. Surgery was 6 weeks ago so I gave it a pat on the fender to let it know I haven’t forgotten about er. :)
  • Sad
ctfjr
L3800HST
Dec 7, 2009
1,982
2,541
central ct
swapped my forks for the bucket (I love quick attach!).
Also was able to get the pto hooked up to the post hole digger. Another pia job. Same story as last time the freakin balls weren't retracting fully when the collar was pulled back.
Maybe my storage plan for the phd isn't so great after all. I hang it from the deck with the auger just touching the ground. I grease the hell out of the coupler every time I put it away.
I had to repeat the same process as last time - soak with Mouse Milk, leave overnight, this morning soak with WD40 and it slid right on . . .
I have to drill 10 more holes for short 4X4 posts along part of the driveway. They are going to hold small led 12v lights. Its too hot n humid right now to do it but if it cools down I'll do it this evening.
As far as the phd goes I think I'm going to remove the entire shaft after each use and store inside. It is definitely my least favorite attachment to hook up especially as my 75th birthday is approaching. That's when I become old :(
7,007
Great. I'll plan now for the disappointment to come. ;)
6,761
Maybe my storage plan for the phd is so great after all. I hang it from the deck with the auger just touching the ground. I grease the hell out of the coupler every time I put it away.
It was about 80 for my dad. He was running along like he was still 50 until he hit about 80. Slow but steady decline after 80 and a couple health problems that would have been minor in prior years really knocked him in the dirt in his early 80’s. Keep running until you can’t. None of us have forever.
aaluck
Oct 9, 2019
1,003
844
Snowdoun, AL
Great idea. I learned this when I purchased a used one on the shaft stuck, no slide. Took 3 days of soaking and strapping one end to a 4x4 and the other to the bucket (pulling it apart) to get it unstuck. Sanded and have never left it outside since.
B737
LX3310
Jun 9, 2019
2,022
2,205
Box bladed 160 feet of driveway, then spread 30 tons of 3/8th Delaware :)
Reactions: 14 users
ctfjr
L3800HST
Dec 7, 2009
1,982
2,541
central ct
Great to hear that I'm not old yet. :)
But I think someone forgot to tell my body.;)
lol little footsie :)
I made that comment tongue in cheek. My kids / wife and our friends all tell me I'll never grow up. That's just fine with me.
Life is an adventure - keep exploring!
tbeckett
Kubota M5660SUHD, Monroe Tufline Disc, Woods Bush Hog, 60" Grapple
Jun 3, 2021
Columbus, MS
Daddy is 91. He was driving 3 hours one way to see his Lady Friend every week and all was good. He was pretty much fine until the Covid lock down last year and in August started falling some. I did not realize that 4-5 months of inactivity would set him back so much. We are getting him back in shape slowly but surely. All I can say is keep on moving and keep on keepin' on. It is worth the effort!
