3 point Log Skidder/Trailer hitch
alter
26
IL
Hello, I'm looking for an attachment that would enable me to hook a chain around a log and lift it up with the 3 point to be able to drag it out of the woods. Ideally I would like it to be compatible with the QH10 quick hitch on my Kubota L2501. Also ideal would be if it had a class3 hitch receiver on it so that it could double as a trailer hitch that I can raise and lower. Does anything like this exist? Thanks
6,822
You could go with something simple and relatively economical like this:
[/URL]
Or go with a more versatile but much more costly skidding winch like this:
There is a pretty wide variety of skidding winches and most I’ve seen have an option for a trailer hitch of some sort.
Of course if you have some rudimentary fabrication abilities you can get a plain hitch tube such as used on RV bumpers and attach it to whatever you like if it doesn’t come with a cost effective hitch.
alter
26
IL
[/URL]
Skidding winches are cool, but expensive and Im just looking for a simple attachment i can lift a chain with and lift, to pull logs with the tractor, along with a trailer hitch for now.
i7win7
Feb 21, 2020
3,377
3,993
Central, IL
Lower 3 point, loop chain over top hook, lift and drag
7,347
This is a redneck approach on a little BX. Your tractor is obviously much larger.
A drawbar (Cat 2?) with a simple piece of threaded rod (5/16 or 3/8"?) looped up to top hook. Keeps things from spinning around. Although light, the rod hasn't bent yet.
You could mount a receiver to the drawbar.
My only cautions are (1) lifting the log too high may cause loss of weight on the front of the tractor...possibly flip it over and (2) the 3 point hitch, without any down pressure, the tongue of a trailer can lift the entire 3 PH assembly and possibly try to run you over.
Nice thing is just open the levers, and the whole thing lifts off in 10 seconds. Nothing to disassemble. Maybe could be scaled up to a larger machine.
Could possibly work a shackle on the top hook as well, which gives 2 hook points, but that also increases the risk associated with raising the log, etc.
You can see I also have a receiver hitch down low. Lessens risk of both issues above. A BX doesn't come with a functional drawbar for that purpose. That receiver and drawbar are aftermarket.
UpNorthMI
May 12, 2020
849
568
Up North, MI
Take a look at the Titan 3pt Transformer hitch fitted with the optional Logging Boom
I use this set up on my L series tractors to help with log skidding, it's very cost effective at about $250 for both items. I recommend this for what you want to do.
Sorry I can not comment on the QH compatability. Good luck in your search.
For getting in deep into the trees I use a Farmi 501 skidding winch that I run on the rear of my MX5800, it is fast and so useful, once I get the trees out to a forestry path my smaller L series with the Titan transformer logging boom help out skidding trees back along the forestry paths.
yorkies77
Kubota BX23S
Jun 7, 2020
85
68
Idaho
X 100, and you have a story I can relate to!
Exactly right, we are building a new home and I fell 50 trees from our home site. I skidded all the logs just hooking the chain over the top hook on my quick hitch and it worked great.
Ikc1990
Kubota m125x, m9000, cat 226 skidsteer and other equiptment
Dec 2, 2020
294
131
Vermont
I have a trailer hitch adapter on my 3point hitch picked up for 40 bucks picked up a couple weld on hooks welded them on that can still use 2 inch receiver with a Clovis or Clovis hook or on ball and have several welded hooks on it too also have one welded on top of back blade that's super handy too
FTG-05
Jul 21, 2013
346
190
TN
Used to do that with a hitch, chain and a Logrite log tongs. Then I got a grapple. I've never used the tongs since. Side note: They are the Logrite 28" version (the largest); if anyone wants them, come get it.
Before:
New, mo bettah way:
Plus the added benefit of making bucking logs far more easier and comfortable:
And I'm serious about the logging tongs: I-65 near the AL/TN border; free for the taking.
alter
26
IL
Before:
New, mo bettah way:
I do have the 3rd function kit and am planning on ordering a grapple within the next year but even if I order it now I will be waiting but even once I get the grapple, my trails are too narrow to carry large logs very far with the log sideways in the grapple. So I anticipate still having to drag logs behind the tractor.
I totally would take you up on your offer of the tongs if I wasn't so far away. Thanks
Chinook3
BX2380,FEL344S,LP forks,BX2816snowb50,mmm60, log arch, Wicked 55 grapple
Nov 13, 2020
31
24
Check out Northern tools. I got there log arch. I think it was $150 and it works great, simple and effective.
Chinook3
Ikc1990
Dec 2, 2020
294
131
Vermont
Or a boom pole
twomany
B7200
Jul 10, 2017
793
139
Vermont
I have pulled the scoop bucket off the frame and used the frame to pull out a couple of logs at a time. The structure works well. And it's only two bolts to drop the scoop.
Damn, I've run that scoop for over 30 years, CAT 2 and CAT 1, bent pins and all.
I might have paid $200 for it "back then". What a deal. It's hitched on now as I'm moving fill from a high spot to a new bank next to the house.
Like this, but faded red
GrumpyFarmer
5,227
Chinook3
Nov 13, 2020
31
24
Check out Northern Tool and their log arch. Sounds like what you are looking for.
Chinook3
GrumpyFarmer
5,227
I started with the base part from a back blade and added based on my intended use from there. It’s modular so you can use as a hitch or put a wood vice in or a box or whatever will slide into a 2 inch hitch. Add some shackl bases for shackles
81B4BEA2-B2A9-49DE-AF75-0C08D9982A73.jpeg FAE04F79-22B9-4A6A-B082-DEC741DE0FD1.jpeg 06F834A0-D553-4196-94C7-68DDDBF47C8F.jpeg
Magicman
Oct 8, 2019
6,057
9,535
Brookhaven, MS
knotholesawmill.com
I use a logging winch that connects to the tractor's PTO:
The hitch receiver is removable and of course the hitch can be flipped for lower attachments.
