Attaching LA535 Loader with a Toothbar
je1279
Dec 6, 2020
828
581
Upstate NY
I know many of you never remove your loaders but for those who do, and also have a toothbar, do you need to remove the toothbar to reattach the loader? For the life of me, I can't get it to drop into the bracket with the toothbar on. Both the tractor and loader are in my garage with a concrete floor where I have attached the loader prior to the toothbar without a problem.
6,932
I put my Piranha Tooth Bar on within a year of getting tractor 8 years ago.
No issue......what's causing the grief to connect? Alignment, height, other?
I know your LX connects differently than my older BX....just trying to figure out why/how the TB would interfere....
je1279
Dec 6, 2020
828
581
Upstate NY
Only thing I can think of is the geometry change. Without it the loader used to align properly when dumping the bucket and drop into the bracket. Now at the point where it used to drop in it comes close but doesn't seat and then dumping the bucket further lifts the loader out of the bracket.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,639
1,912
Near Lancaster, PA, USA
In the picture it looks like the bracket on the FEL needs to rotate a bit more. Try moving the joystick as though you are raising the bucket and I'll bet it drops in.
6,932
I agree with Chim....try a very slight pull on the 'stick....
The TB has extended your cutting edge a couple/few inches. I think you have your FEL on/off quite often. Just wondering if you need to adjust for that, and maybe not extend the curl cylinder as much, as you've rocked the rear mount enough to have to compensate for it....if that makes any sense..o_O :unsure: :geek:
lynnmor
B2601-1
May 3, 2021
1,592
1,356
Red Lion
Could you run the tractor up on a couple of boards to see if that works?
je1279
Dec 6, 2020
828
581
Upstate NY
Thank you all for the suggestions. I did what @chim recommended and I'm back in business. I owe you a drink buddy!
Jchonline
599
Red Feather Lakes, CO
Perhaps a piece of plywood or 1x along the back side of the bucket on the floor next time you need to disconnect it would help offset the extra dimension up front for the tooth bar?
je1279
Dec 6, 2020
828
581
Upstate NY
Thanks. I will certainly try it the next time I remove it.
2,159
If your tires were clean you would probably not have any problem (LOL)
je1279
Dec 6, 2020
828
581
Upstate NY
Haha somehow the tires are the cleanest things on the tractor currently. She could definitely use a bath!
Patent Guy
LX 2610, LA 535, BH 77, SU R14 Tires, 1.5" Spacers, 2 remotes, LP 3rd Function.
Nov 14, 2020
East Tennessee
I have same tractor, loader and toothbar. It is doable without any additional plywood etc, you just have to learn the different angles for the dump and not care if you scar the concrete a little with the bar teeth. All the best!
je1279
Dec 6, 2020
828
581
Upstate NY
Lol like this?
JustinB60
LX2610 w/LA535, QH15, PL1242
Mar 31, 2018
127
How do you like those R14’s on the turf? Nice tractor, supposed to get mine delivered tomorrow
je1279
Dec 6, 2020
828
581
Upstate NY
Congrats and thank you! R14's are great on turf as long as it's not soaked and you keep the weight down. I needed to mow with the loader and bucket on last week and I spun the rear tires a couple times and that doesn't normally happen with the loader off
