I have a 2012 M8540 w/ about 1600hrs on it and recently the AC started to blow less cool so, being the genius I am, I hit it with some more 134a and likely overcharged the system. I'm right in the middle of haying (hay on the ground) so I had to rake with the doors wide open at 90+ degrees out. Sucks. Had to twist the Kubota dealer to come check my system as I had cleaned every screen and filter with no luck. I pulled the seat and opened up the floor to get to the evaporator which wasn't dirty at all. The mechanic had little experience with AC (thanks) but did have a set of gauges and bled off some refrigerant until the low side was in range ( btwn 20 and 30) at idle. The problem we ran into was at operating RPM (2200), the compressor started to kick off and on about every 15 seconds. Lo side would drop to below 20. Air blows colder but not the very cold air the system has blown in the past.
Soooo ..... any ideas? Mechanic said they could evac the whole system and then refill with exact amount of refrigerant and that might help. Any possibility if it being the lo pressure switch? He seemed to think the switch was "all or nothing" so not likely a problem.
