fj40dave
Sep 24, 2009
425
257
Yelm, WA
Found a tear in the plastic grill from a stick....so.....today I got out the electric glue gun and grinder and added some expanded metal to the grill guard.
arm
b3030
Apr 20, 2018
Iowa
I've seen this before and really like it. Hope to find some time this winter. Good work
Sent from my SM-G920V using Tapatalk
tiktock
225
Plaistow
I used my bx1880 to drag a massive felled pine from a ditch, then carry the sawed up sections to a little storage area. Was surprised it had the umpf to drag such a massive tree section with limbs intact through thick compost.
The tree was at lest 24-30"" and a challenge for my little 18" chainsaw so I used the tractor to rotate the log as I cut through once I had it in two pieces.
The tractor hit 20 hours during this process. Fantastic! Cannot believe how much work I've achieved in those first 20 hours.
crappy pic of the process:
tiktock
225
Plaistow
Flat tire on the front today...found a nail in it. Went overboard and both plugged it as well as added half a jug of slime to both front tires at the same time. Ran on it all afternoon and held pressure so should be fine.
Holleyman
Kubota B6001, Caterpillar 252B, AM General M813A1, Ford 8N, Komatsu PC30
Sep 25, 2013
70
80 acres in Athabasca AB
Flushed the front diff with nice new synthetic 75W-90 and ran the machine doing light work for several hours. Parked back into the garage only to find a nice puddle of nice new synthetic 75W-90 a few hours later coming from the front driveline housing.
I just finished rebuilding the front final drives and they run beautifully. I guess the front differential will be re-bearinged and re-sealed.
The joys of owning an old tractor.
4,409
Good on ya digger,, the more you do the more you learn and you can head things off before they get bad :D
mike33s
I got my B2601 on Thursday of last week.
Today I moved about 2 yards of dirt, combined a brush pile that was ~20' x 10' into a much smaller brush pile in preparation to burn it, cleared an area around my compost pile and filled one large hole in the yard near the pond.
mpham
B 2650 cab
Nov 15, 2016
152
Massachusetts
Moved a few items around the yard getting ready for fall/winter. Then I gave it a bath as I was washing the cars anyway.
JeepinMaxx
BX2660, LA243 FEL, RCK54P-23BX MMM, BX2751 QH Subframe, BX2750D 50" Blower
Mar 27, 2018
296
9
Columbia, CT
Used my FEL to help me re-install the tire carrier & spare tire onto the back of my Jeep
hope to float
L3450
Feb 18, 2018
490
61
Ireland
Yesterday, i took her golfing. It was only a 10 mile blast down the main road :D
Golf course tractor had a burst pipe (still not fixed) and jobs were piling up. On a side note, had to run her in 4wd all day because industrial tyres have shite grip on grass at speed. Had to fill her twice
fj40dave
Sep 24, 2009
425
257
Yelm, WA
Kill Switch & Light Bar
Wired up a 6 place BUS with weather proof container enclosure under the hood for this lighting addition and future rear facing lighting(backhoe work).
Kill Switch is obvious for a reason: See it and give up, move along.
Both work great.
shootem604
Apr 23, 2018
874
British Columbia
Over the weekend, I dug a number of holes for fence posts with the backhoe, spread about 12 yards of wood chips around in the horse paddock, then strung the wire and used the backhoe to tension it while I stapled it to the posts.
fj40dave
Sep 24, 2009
425
257
Yelm, WA
Attached these two tow/tie down hooks and welded a plate between them for increased strength. I think these will work great for strapping the tractor on the trailer.
I picked the hooks up at a garage sale this Summer for $5.....they are from a Nissan...Titan I think.
Holleyman
Sep 25, 2013
70
I unloaded, unboxed and assembled the casters on a new tool box. Found this one that is pretty close to Kubota colour. My old late 70's Snap -On box was very tired.
7,077
Florence made it to upstate New York last night.
Worst driveway damage I’ve had in several years.
Not perfect, but a whole lot better. Thankfully most of my stone stayed at the end of the driveway.
Did it with box blade, and that’s my little stand I park it on when not in use.
hope to float
L3450
Feb 18, 2018
490
61
Ireland
I spent quite a while letting the air out of Hope's tyres so that I could get her into the shed out of the storm. Funny thing is she fitted in last year :confused:
Must be letting herself go now that she has settled :D
kris77
105
CA
Cut down about 8 small trees behind the shed. Getting ready to level off a spot for all the implements and trailer. I really need a backhoe. Kicking myself for not getting one when I bought this.
Also let my 9yr old son drive the tractor for a while. Loaded up logs in the front bucket and let him drive over and dump on the brush pile. He had a blast. Feels good to see him enjoy things like that.
And I cannot get the image to rotate the correct way for some strange reason
