Looks like whomever I bought this lower from required everything and chipped the harness up badly. I need a new harness but struggling to find one. Any suggestions?
So far, I’m in seat switch, brake switch, ignightor, and coil pack.Looks to be about $200-300 for a new harness. Depends on the serial number which specific one to get. Any dealer should be able to help you, including Messicks and Coleman Equipment (mail order).
How much repair work is needed on the old one?
Are you working from a Workshop Manual in determining components needing replacement?So far, I’m in seat switch, brake switch, ignightor, and coil pack.
But they butchered this wiring harness. I spent $600 on the mower knowing it turned over but didn’t run.
Only turns over. Wont run. No spark to the coils. Have a manual. Just a mess.Are you working from a Workshop Manual in determining components needing replacement?
Does it run now?
Which manual do you have? If you are working from a Kubota manual trying to get a Kawasaki engine running..... good luck.Only turns over. Wont run. No spark to the coils. Have a manual. Just a mess.
