Top & tilt for MX-5200
jim0316
MX5200HST
Oct 24, 2018
Tampa, FL USA
The amount of tilt is very difficult to control. The movement is so fast when the valve is activated that I have to tilt back and forth several times in order to get it where I want it. Does anyone know how to slow the movement down?
MOOTS
MX6000
Jun 27, 2019
1,923
2,205
Canton, Georgia
Flow restrictor is what you need. I’m sure other places sell them, but Brian at fit rite has them.
MtnViewRanch
796
233
Lakeside Ca.
Here are some generic orifice fittings.
I would get the .031 and drill out as needed. While 1 should work on the rod end port, I recommend that you use 2, 1 at each coupler at the hose end is the easiest way to do this with generic fittings.
