It appears the two hydraulic hoses closest to the stick are leaking at the connection point on the loader control valve.
I first noticed the leak about a week ago. I cleaned the area up to confirm it wasn’t from assembly but, I checked the tractor out after working it yesterday and fluid is everywhere.
I found the two hose fittings weren’t fully tightened. I tightened the fittings and cleaned the valve, hoses, fittings and the tractor again. However, this afternoon I inspected the area again and those fittings are still leaking.
The tractor has 15 hours on it. Is this an easy fix or should I contact the dealer?
Mike
Mike
